928 Forum 1978-1995
Sponsored by: 928 Specialists
Just Peachy OB project
Old 02-11-2016, 10:41 PM
  #796
77tony
77tony's Avatar
Back up to paint shop on Mon to take care of a few small issues. Hoping the Infiniti Box sytem will be delivered in the meantime T
Old 03-05-2016, 08:13 PM
  #797
77tony
77tony's Avatar
Paint correction now done, trailered J.P. back to the shop. Glad to see the rest of the Infinity Box system came in while she was away. Will place initial wiring, connector, etc., order on Mon. While awaiting that order, plan is to fly over to JAX on Wed to meet with Carl (FLYVMO). Plan is to take lots of pics and ask questions regarding Carl's I-Box install that's almsot done and car is still apart. Will also be joining some other 928'rs at Amelia Island Concours. T
Old 03-05-2016, 08:55 PM
  #798
BC
BC's Avatar
Another install for that electrical setup. Nice! Post pics.
Old 03-05-2016, 09:05 PM
  #799
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
That's awesome, but to keep it 928ish.....scrap all that wire and just buy a 1,000' spool of gray
I really need a labeler. Do the labels from that unit stick good to wires?
Old 03-05-2016, 11:37 PM
  #800
77tony
77tony's Avatar
If wire is labeled on both ends I don't see why not Have not used this labeler as of yet. Carl has so it must be good T
Old 03-05-2016, 11:45 PM
  #801
Ducman82
Ducman82's Avatar
which label maker is that?
Old 03-06-2016, 12:22 AM
  #802
77tony
77tony's Avatar
Amazon.com: Brother Pt-d400 Label Maker: Office Products Amazon.com: Brother Pt-d400 Label Maker: Office Products
Old 03-06-2016, 09:08 AM
  #803
FLYVMO
FLYVMO's Avatar
Car is looking great Tony!
Those labels stick very well, they are not going to come off
Cheers!
Carl
Old 03-06-2016, 11:54 PM
  #804
jbrob007
jbrob007's Avatar
Tony, Just caught up reading this entire thread... DAMN! This build is AWESOME! From the tear down, stripping, rebuild and engine, color choice & the OB look and the wheels are spot on! One helluva sleeper too... On my project, we've been struggling over the addition of a wing (either S4 or an after market) but after seeing JP without it I'm having 2nd thoughts... Both cars are very similar from the rub strips, side markers, rear wiper & rear seat delete, albeit the comparison ends there. Are you guys going with a wing or gonna keep her *** end as is...? Again, very nice job... She's a beauty!
Joel
Old 03-07-2016, 01:06 AM
  #805
77tony
77tony's Avatar
Thank you Joel, Been following your thread and your OB looks superb Original plan was to mimic the rear spoiler tested on the early concept cars. Even went ahead and tried a few out and eventually nixed the idea. Personally never liked the S4 rear spoilers on pre 87's. Sorry and hope this helps to persuade staying with that clean OB look. Purchased a used front Euro "S" FBC that allowed ducting and increased air flow to the front brakes. Hardly noticeable down low and no need for the "S" type wrap around lower section. T
Old 03-25-2016, 10:03 PM
  #806
77tony
77tony's Avatar
Most parts/tools ordered are now at the shop so time to get this project rolling. A small shelf will sit inside compartment in the rear seat delete just above the sub box. This will house both the rear power & inMotion cells and offer easy access to cells, fuses, etc. T
Old 04-06-2016, 07:06 PM
  #807
77tony
77tony's Avatar
Master and front power cells mounted where the CE panel used to be. Rear power and InMotion cells mounted in rear seat delete cabinet behind pass seat just above sub box. Starting to look like a system. Spring Fling in a few days and not sure if she will be ready in time. T
Old 04-06-2016, 08:47 PM
  #808
FLYVMO
FLYVMO's Avatar
Looking good Tony!
Very clean looking install. Starting to look like a modern electrical system. You may want to rotate the Master Cell 90 degrees counter clockwise. Otherwise you won't be able to read the display unless you tilt your head 90 degrees
Cheers!
Carl
Old 04-06-2016, 08:50 PM
  #809
77tony
77tony's Avatar
Originally Posted by FLYVMO
Looking good Tony!
Cheers!
Carl
On it ! Thx T
Old 04-11-2016, 02:05 PM
  #810
77tony
77tony's Avatar
Let there be light ! These just in from the UK T
Quick Reply: Just Peachy OB project
