928 Forum 1978-1995
Sponsored by: 928 Specialists
Just Peachy OB project
Old 09-15-2015, 09:29 PM
  #751
FLYVMO
FLYVMO's Avatar
Looking good Tony!
Did you have time to test it out?
Carl
Old 09-15-2015, 09:40 PM
  #752
77tony
77tony's Avatar
Originally Posted by FLYVMO
Looking good Tony!
Carl
Carl, Thanks again for your advice. Will test tomorrow and report back
Old 09-15-2015, 09:43 PM
  #753
MjRocket
MjRocket's Avatar
Default Just Peachy OB project
A writeup perhaps?
Old 09-15-2015, 09:57 PM
  #754
77tony
77tony's Avatar
Originally Posted by MjRocket
A writeup perhaps?
Mj, Here you go: http://www.dccontrol.com/FK75.pdf T
Old 09-15-2015, 10:17 PM
  #755
FLYVMO
FLYVMO's Avatar
Maineporsche did a write-up on this install utilizing the stock wiring, which would probably apply better to MJRocket's setup: https://rennlist.com/forums/928-foru...e-cooling.html
Tony has a custom setup and is wired differently (his car).
Cheers!
Carl
Old 09-15-2015, 10:43 PM
  #756
MjRocket
MjRocket's Avatar
Thank You Gentleman.
Old 09-18-2015, 10:51 PM
  #757
77tony
77tony's Avatar
As most probably know this interior came out of a stored, low mileage 79 and it's finally met it's match-time. Searched hi & low for black & brown pascha material and of the four color combo's, it's the one that's NLA. Contacted Rob Budd & shipped out the front seats today for a similar color combo: black & tan with black vinyl side bolsters, backs, etc.. Plan was to drive out to the upcoming Frenzie, but Rob Budd's a bit backed up (that's a good thing) and I should have planned a little further ahead for this. Will be in CT visiting folks early next week and hitched a ride with Bob (voskian) in his beautiful GT for Frenzie next Thur so it's all good. Looking forward to meeting up with all at Frenzie next weekend. T
Old 10-07-2015, 11:06 PM
  #758
77tony
77tony's Avatar
Added a 6 place fuse block in the spare tire well to clean up things out back. A crude but effective version of Carl's (FLYVMO) modern electrical system being installed in his modern day GT. T
Old 10-08-2015, 09:37 AM
  #759
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
WYAI put a circuit ID label on the cover over each fuse,
this will make troubleshooting easier
Old 10-08-2015, 02:50 PM
  #760
77tony
77tony's Avatar
On it Stan, printed these out last night and will attach later today. T
Old 10-12-2015, 06:00 PM
  #761
77tony
77tony's Avatar
WIT, cleaned up the battery box and coated bottom with a rubberized sealant. Something was etching into the window tint. Took drivers door apart and discovered the felt window stop as being the culprit. Ordered a new one from Roger. T
Old 10-14-2015, 01:40 PM
  #762
FLYVMO
FLYVMO's Avatar
Hey Tony,
That felt guide looks like it is not factory. Is that a home made version? Who put that in there? :evil grin:
Cheers!
Carl
Old 10-14-2015, 02:06 PM
  #763
Dinsdale Piranha
Dinsdale Piranha's Avatar
Hey Tony,
Cheers!
Carl
I put it in Carl.
It's original to the car , the factory replacement parts had felt that was too thick to fit into place without massive drag on the windows.
I used some 1/16" industrial felt (eBay 2$) to repair mine. Way cheaper than factory parts that don't fit well.
Old 10-14-2015, 03:45 PM
  #764
FLYVMO
FLYVMO's Avatar
Originally Posted by Dinsdale Piranha
I put it in Carl.
I noticed when I put the new factory replacement guides in, they needed to be compressed and reshaped somewhat. Otherwise, as you say, they put too much friction on the window, even at the most retracted (loose) position.
Cheers!
Carl
Old 10-14-2015, 06:12 PM
  #765
NoVector
NoVector's Avatar
I put it in Carl.
+1. For comparison, my original on the left and new on the right. The new one put way too much stress on the window. Car looks great, Tony!
Quick Reply: Just Peachy OB project
