928 Forum 1978-1995
Sponsored by: 928 Specialists
Battery Cable Length?
Old 09-23-2011, 11:55 PM
danglerb
danglerb's Avatar
Battery end would be the one I want sealed the best, not much room to work down in the battery box.
Old 09-24-2011, 01:06 AM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Originally Posted by the flyin' scotsman
Could the new cable be made up with one end, alternator, routed under the car in the normal fashion, brought into the battery box, cut to length and the battery connector then secured?
Possibly. But you can put the battery end on first, then the Oring crimp on the other end, is no larger than the cable itself..and would snake anywhere.
Id think.
Old 09-24-2011, 01:27 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
I have changed my F-250 from 6 awg & 8 awg cables to 2 awg, with a noticeable change in starter operation. (The Ford starter is a very high-draw design.)
I have thought about changing the 928 to 2 awg cable, and had done a little quick research.
2 awg American-made welding cable (made of VERY fine 30 awg strands) with rubber insulation, sells for $2.50/foot, including shipping.
The positive cable should be about 9' long, and I took 10' as a reasonable purchase - so cost would be $25.
Total resistance for 10' would be about 1.5 milliOhmns.
It will carry 195 amps continuously with a resulting temp of less than 60 deg C., and will carry 1300 amps for about ten seconds.
I think that tin-plated brass terminals would be acceptable.
Now all we need is terminals, clamps/retainers, and tools...
Old 09-24-2011, 02:26 AM
danglerb
danglerb's Avatar
So who makes the best battery crimp terminals? NOCO?
Old 09-24-2011, 04:07 AM
Jim Devine
Jim Devine's Avatar
Cable ends all the way to size 4/0 here:
http://www.remybattery.com/Departmen...Terminals.aspx
Demo video:
Much heavier ground straps- 1/0 instead of 4 ga.
http://terminalsupplyco.com/Store/Pr...spx?pc=GS-1015
Need to use this at the neg battery terminal to use the 1/0 strap:
Made of copper- not lead:
http://www.greenboatstuff.com/ticobate.html
Old 09-24-2011, 04:12 AM
Speedtoys
Speedtoys's Avatar
When you do crimp it, I like this:
http://shop.genuinedealz.com/items/i...itemid=5229952
Add a 2lb sledge, then solder...it's never coming off.
Old 09-24-2011, 05:37 AM
danglerb
danglerb's Avatar
So I'm thinking I have 4 wires on my positive terminal, the fat one, the two to the CE panel, and one to an amp for the stereo.
What size wire is used for the fat one now, what is being suggested?
Which style of battery clamp, assuming one of these fancy cast copper types, but straight, left or right?
Keep the lugs on the CE panel wires and connect to the clamp bolt? (same for amp)
Do the CE panel wires need replacing, can they be?
Once we know the length, why not have one of these marine suppliers do at least some of the termination?
BTW clamps at all the sources look the same to me so far.
Old 09-24-2011, 08:10 AM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Sterling mentioned that the original cable is somewhere just north of 2 gauge, well south of 1 gauge. If I can get a 1 gauge that will fit in the factory guides I'll go that way, otherwise 2 gauge will have to do it. I can suffer the added weight.
I have both sizes of welding cable, but not at the same place where the car is.
Marine cables are tinned copper to resist corrosion. Closer in copper construction to an automotive cable than to welding cable, so maybe not ulra-flexible. Question then comes to oil/solvent/heat resistance of the insulation. Is the welding cable insulation too thick for the factory guides? I'll have measurements to play with for thickness and make the decision before the cable cutters come out. The local marine supply place (West Marine) has all the pieces and the marine cable in stock, and will do the crimping for me.
So at this point the diagnosis is in, and the cure is defined. All except for the length of the cble eye-to-eye. Anybody know that dimension?
Old 09-24-2011, 08:35 AM
the flyin' scotsman
the flyin' scotsman's Avatar
Perhaps Mr. Anderson could shed some light:
Old 09-24-2011, 12:07 PM
Earl Gillstrom
Earl Gillstrom's Avatar
dr bob,
The overall length of an '88 battery cable including ends is 12' 3". I would think that an '89 cable would be the same length as an '88.
Earl
Old 09-24-2011, 12:19 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
Be gentle with the clips that hold the + cable to the body, they're NLA.
Old 09-24-2011, 07:15 PM
SMTCapeCod
SMTCapeCod's Avatar
http://www.summitracing.com/parts/TAY-21542/
Old 09-24-2011, 09:41 PM
dr bob
dr bob's Avatar
Originally Posted by Earl Gillstrom
dr bob,
Earl
Thanks, Earl. That's exactly the number I need.
I have a crimper for the regular 1- and 2-gauge lugs, the ywo-arm-squeeze type not hydraulic. Not sure if it will work well with the battery end, but will certainly do OK for the starter end. The 1ga is under $3/ft at the marine store last I looked, buy the ends and they install them.
For those playing along at home, the picture of Mark's factory cable shows that it comes with the grommet/pass-through for the battery well, and all the extra protective sleeves in all the right places for a relatively drop-in installation. If you aren't comfortable making stuff like this, and/or don't have the tools or experience needed to do it right, the factory replacement piece is a very good and accurate solution.
Depending on time available, I'll try to do a simple how-to for the diagnostic part anyway.
Old 09-24-2011, 10:00 PM
dr bob
dr bob's Avatar
Originally Posted by SMTCapeCod
That 1/0 cable is overkill on capacity, and would be a real chore to route and attach I'll speculate. Plus, none of these cables reveal what the insulation OD works out to, so more research is needed to make sure the new cable can be installed in the original guides.
Old 09-24-2011, 10:41 PM
Earl Gillstrom
dr bob,
The OD of the cable including insulation is .540". The two extra sleeves at the starter end are 7" and 11" long with an OD of .750".
Earl
Quick Reply: Battery Cable Length?
