928 Forum 1978-1995
Sponsored by: 928 Specialists
PWM dimmer for instrument backlighting after upgrading to LEDs
Old 02-14-2015, 08:44 PM
  #226
SeanR
SeanR's Avatar
Originally Posted by Ed Scherer
Got it. Replying now.
And, for the record, I'm out of the AILD-1s at the moment. Ran out of PCBs, so I'll order some more and try to get more units built by the first or second week of March.
Let us know when you get some more in, I have a customer that asked about it a few days ago and might be needing one or two.
Old 02-14-2015, 09:21 PM
  #227
Ed Scherer
Ed Scherer's Avatar
Noted. Will do. Given the interest again, the priority just went up.
Old 02-21-2015, 11:11 AM
  #228
longleader
longleader's Avatar
Sean,
I have one if you need it I can send it to you and you can replace it later.
Larry
Old 02-23-2015, 02:24 AM
  #229
Nostram
4th Gear
Nostram's Avatar
Originally Posted by danglerb
PM may be blocked until you have more posts, like 5 or 10.
Thank you for the heads up. I will post as I see a need to, would hate to spam post just to get my count up.
Thank you for the response, sorry I took so long in replying to it. I definitely want one so please keep us updated as to availability. If it works as well as I expect it to I can see myself wanting a few more in the future. *grins*
Old 04-04-2015, 04:56 PM
  #230
Ed Scherer
Ed Scherer's Avatar
Status update: I got the new (slightly updated, now at rev. 1B) PCBs in a couple of weeks ago. I finally got around to building one a few days ago (needed to make sure this PCB revision didn't have any flaws), and it worked just fine, so I'll be starting another batch here within the next few days. Should have more to sell within a week.
Didn't want y'all to think that I forgot about this.
PCB Top Side:
PCB Bottom Side:
Assembled PCB:
Old 04-04-2015, 10:12 PM
  #231
AirtekHVAC
AirtekHVAC's Avatar
Ed, put an assembled kit aside for me. I missed out on the last order....
Thanks!
Old 04-05-2015, 12:05 AM
  #232
Nostram
4th Gear
Nostram's Avatar
Thanks for the update, definitely looking forward to it.
Old 04-05-2015, 06:02 AM
  #233
yaskota
yaskota's Avatar
Aloha Ed!
Coincidentally accelerating my whole-car LED upgrade, so...
Please put me down for (1) AILD-1 Main Unit (Assembled) & (1) AILD-1 connection kit for '78-'89 Porsche 928.
Mahalo & sending identical PM!
-tom
Old 04-05-2015, 12:33 PM
  #234
The Patman
The Patman's Avatar
I too have done the LED change over, and Sean says I need one of these...so...I'll need one as well. Let me know.
Old 04-29-2015, 01:58 AM
  #235
alxdgr8
alxdgr8's Avatar
Any updates on availability? Just found this and I'd like to use one for an Audi project I'm working on currently.
Old 04-29-2015, 09:12 AM
  #236
davek9
davek9's Avatar
Hi Ed, very satisfied w/the 2 units I have.
Please put me down for an additional two assembled units.
When can we start ordering them from your Website please?
Thank you,
Dave K
Old 04-29-2015, 10:50 AM
  #237
Alan
Electron Wrangler
Alan's Avatar
Ed - I would be interested in one too.
Question - how easy would it be to modify your design to control interior lighting LED's as a soft fade out and relatively quick fade up module. Concept would be to have the device fed by the existing delay relay - for the main delay function then trigger the LED fade functions Quick on and slow fade off.
Approx specs: <0.5 sec fade-up (variable?), Variable (pot) Fade-down in range ~1 sec - ~5 sec.
Challenges are your existing module is a supply side device while we need a ground side device for the interior lights - however generally this is even easier (just different). And you do need a variable ~linear fade option Vs. an adjustable level - But still a very similar circuit. Depending on config this likely needs a very low quiescent current if it's always supplied or a self-powered mode (for the fade time) if it's supplied by the interior light switching circuit...
Thoughts?
I developed a purely linear circuit years ago to do exactly this for the stock incandescents - but of course it's no good for LED's.
Alan
Old 05-27-2015, 11:58 PM
  #238
Nostram
4th Gear
Nostram's Avatar
Checking to see if there are any updates. =)
Old 05-28-2015, 03:10 AM
  #239
Ed Scherer
Ed Scherer's Avatar
Yes... I'm happy to report that I just finished up a batch of ten units last night. I'll be reviewing my various e-mails, Rennlist PMs, Rennlist posts in this thread, etc., and contacting people who were on the "informal waiting list" in the order of those requests, and then providing instructions on how to order. Expect to hear more Thursday evening when I get some more time to sort that out.
I expect to start another batch right away, then, as I suspect the current batch won't last long.
My apologies for how long this has taken; I've been dealing with some family problems over the last year that have consumed an unbelievable amount of time and energy. Perhaps I'll share that story over in Rennlist OT sometime.
Thoughts?
Alan
Sounds quite doable. And would probably be an enjoyable challenge. But... it's unlikely that I'd be able to work on it for quite a while, given how little time I have had lately and am likely to have in the near future.
Old 05-28-2015, 10:51 AM
  #240
Pagnobito
Pagnobito's Avatar
Great project, let me know when you have built some more please?
I faced similar challenges when designing a replacement for the acceleration sensor under the seat on PSD equipped cars, not taking all the credit though as JDS is my partner for them. Far lower demand though so still all hand made.
Love the desktop milling machine, does it also cut aluminium?
Quick Reply: PWM dimmer for instrument backlighting after upgrading to LEDs
