928 Forum 1978-1995
Sponsored by: 928 Specialists
Looking for good 89+ front engine harness
Old 09-18-2011, 10:32 PM
Tom. M
Deleted
Tom. M's Avatar
You've got it Adam....just remember..no A/C
Malcolm...I think I'll give the reconstructed on a go for now..but good to know I've got options..
Old 09-18-2011, 10:53 PM
Dictys
Dictys's Avatar
Out of interest what is the total length of the harness and it's width. I am thinking of building a new harness for my 90 as a bit of a project and wish to build it without removing the present harness for the moment.
Old 09-18-2011, 10:55 PM
SeanR
SeanR's Avatar
Here's a picture of the last '82 harness in the world. Took it today. $400 sitting here.
Has nothing to do with this thread, but the one it's replacing is going on a tack board so I can make more.
Old 09-18-2011, 11:06 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,555 Likes on 1,235 Posts
94" long when stretched out straight. I could measure the length of all the connections along the way, but anyone that's gonna build one had better have a harness in front of them to use as a template.
Old 09-18-2011, 11:19 PM
the flyin' scotsman
the flyin' scotsman's Avatar
thats a pile of beans for some wires and connectors.......using a tack board/template is the way to get repeatable results. In the telecom world we had a whole dept dedicated to wiring, harnerss, molded connectors etc etc......not as simple as some precieve.
Old 09-18-2011, 11:24 PM
Rob Edwards
Archive Gatekeeper
Carl's got some nice shots of the template/setup they use to build engine harnesses:
http://www.928motorsports.com/parts/...reHarness6.jpg
Old 09-18-2011, 11:41 PM
the flyin' scotsman
Rob.....thats a good example of how a template could be constrcucted but its even more practicle when its vertical to do the wiring of the harness then move it on to connectorizing at another stage. the harness can be held together with waxed string until connectors are placed and soldered and tested then it can be wrapped.
Ensure wire guages meet the amperage rating of the respective circuits and connectors are well sourced.
Old 09-25-2011, 12:32 AM
Tom. M
Deleted
Tom. M's Avatar
Got the harness back today and it looked great ...The oil level sender wire was broken, the starter circuit was messed up, the alt excitation circuit was run outside the harness..and the temp one was crusty too. All this was fixed up by Chris and heatshrink wrapped to keep it nice and dry.
Put in back in the car and reconnected everything... No smoke....and fired right up. I also put the GT brains back in and it idled great for the 5 minutes or so I ran it. Idled where it should, alt started charging right away, oil pressure right up to 5 etc...
More testing tomorrow to see if it cured my weird idle issues and the bad running in the rain.. keeping my fingers crossed..
Old 09-25-2011, 01:07 AM
Chris
Chris's Avatar
Glad that all worked out Tom, now you have 10days (forever, right?) or so to make sure all OK for the trip
Old 09-25-2011, 05:23 AM
Lizard928
Lizard928's Avatar
Chris, are you coming out too? Been awhile!
Old 09-25-2011, 03:41 PM
Tom. M
Deleted
Tom. M's Avatar
Well...although I've got a nice front engine harness...the old issues still seem to be there. Backed out of the garage this am and it started the old..idle up....then down...then up.....but ran ok..till I headed out of the neighborhood...got to the main road and it started running really rough and no amount of throttle could clear it..(Belching black etc)...and then it died....cranked..and it started but I didn't want to take a chance..so back to the house..
Any thoughts?....I've swapped in a different brain and it did the same thing..so I think that rules that out. Temp II was replaced a few years back... Could the temp I cause this kind of issue? Any other thoughts?
Quick Reply: Looking for good 89+ front engine harness
