928 Forum 1978-1995
Sponsored by: 928 Specialists
Machining Cross-Drilled Rotors
Old 03-27-2011, 03:49 AM
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
Angry Machining Cross-Drilled Rotors
I've got some Zimmerman cross-drilled rotors on my S4 and I need to have the fronts resurfaced as I have hit the pad sensors and am installing new pads. Imagine my surprise at the apparent crime against humanity (and brake lathes the world over) for having the temerity to ask a few local chains to mount 'em up and do this job for me! "MY GAWD MAN! Our brake lathe will simply self-destruct!!!!!11!!" was the typical response. My rotors do not have a ridge on them, the holes are champfered (not that it matters) and probably only require the removal of a few thousandths of material to clean them up. These idiots, and I use that term unapologetically, claim the cross-drilled holes will ****** the milling bits from their mount and cast them into the bowels of hell. My reply was: 'well sure enough if you let the idiot savant apprentice in your back room ram the bits into the rotor and attempt to remove .060" from each side in one grand sweep! My next call from you would be to inform me that I need new rotors.' I worked several years for an independent shop and resurfaced more of these kinds of rotors than I care to remember, I even offered to show one of these "professionals" how I did it. No takers, hmmm....
Anyone else encounter this kind of flak with these kinds of rotors? Yes I know the cons wrt resurfacing any kind of rotor but believe me, these have plenty of life left in them, as long as they are properly machined, and I am not hard on brakes (front pads made it >60K).
Alas my quest continues...
Thanks for allowing me to vent.
Old 03-27-2011, 04:21 AM
the flyin' scotsman
the flyin' scotsman's Avatar
I'd go to a better equipped shop.....tools and personel.
I did have a GM head mechanic tell me the OEM rotors were the hardest he had ever tried to resurface
Old 03-27-2011, 08:55 AM
Ducman82
Ducman82's Avatar
I bet a rear machine shop would do it.
Old 03-27-2011, 09:13 AM
shaaark89
shaaark89's Avatar
just go to a machine shop. i've had several sets done by a local shop. no issue.
Old 03-27-2011, 10:03 AM
928drvr86.5
928drvr86.5's Avatar
Hah... I was just thinking mine needed resufacing as i did my pan gasket the other day, and I was also thinking the local shop might **** and moan about them being x-drilled.
Old 03-27-2011, 10:08 AM
123quattro
123quattro's Avatar
If you can't do what you need to do with a scotch brite pad throw them away.
Old 03-27-2011, 10:17 AM
blown 87
Rest in Peace
blown 87's Avatar
QFT, listen to the man, he knows of what he speaks.
Old 03-27-2011, 10:31 AM
chrly924s
chrly924s's Avatar
Most of the parts places that I've observed use the 'once & done'method. Find a REAL machine shop.
Old 03-27-2011, 10:36 AM
Jerry Feather
Jerry Feather's Avatar
I do not remachine my rotors every time I change the pads--only when I have enither scored them , which is rare, or they have developed a surge from wearing unevenly somehow. The new brake pads will seat to the previous worn face very readily.
Jerry Feather
Old 03-27-2011, 10:39 AM
Ketchmi
Ketchmi's Avatar
They can be resurfaced but by having them ground instead of turned. Any shop that can do flywheels can do your rotors. From a shops perspective, why make several light passes when they can do several sets of rotors in the same amount of time? And of course if they do get a bit carried away, it will destroy their equipment and you won't like the finish anyway.
Old 03-27-2011, 12:05 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,069 Likes on 1,181 Posts
Oh come on, I don't see any problems with this:
Old 03-27-2011, 01:01 PM
mickster
mickster's Avatar
Smoove!
Old 03-27-2011, 01:07 PM
GlenL
GlenL's Avatar
Can ya get to the backs that way?
Looks like I'm agettin a new tool
Old 03-27-2011, 02:19 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
More than a few rotor edge lips have been taken off by that method. There's no way to get them guaranteed flat, but at least the new pads don't hang on that nasty 1/8" lip...
Old 03-27-2011, 02:35 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
You can't see the backs, so leave them alone.
I have drilled rotors. I haven't machined them with new pads. I've never machined the 928 rotors. I just change them out when they reach the wear limit (30mm, which is 2mm wear, evidenced by a 1mm edge lip on each side).
Quick Reply: Machining Cross-Drilled Rotors
