oil cooler leak
Team Owner
oil cooler leak
How would you fix this?
JB weld,
or welding.
The oil cooler is dripping from the pipe to housing about 1 drip every 2 mins when hot.
There is less than 1/2 inch tween the fins and rear side of the pipe.
JB weld,
or welding.
Hey Stan,
I've had good results with JB. (Not the quick set stuff). Used it on my snowmobile heat exchanger years ago and no leaks since. Area has to be clean to the point of sterile, with some abrasion for adhesion. It's been several hundred miles now, and the exchanger is located in the front bulkhead and exposed to all the crap the track throws up, like rocks, salt, sand, loose track picks (What caused the problem in the first place), and, oh yeah, and snow......
So, I'd go with this solution as a first choice. YMMV.
Rob.
Rob.
Mine has a small leak too... But it was beat hard by two PO's who had ride height down below 130... Front spoiler and pans were gone too.
The cooler is pretty mangled and I'm surprised how little it is leaking (just a tiny leak on the driver's side at the bottom).
I'm ordering a rebuilt one from Roger if he still has one next month...
Team Owner
JB Welded it,
we will see, thanks for the ideas
Team Owner
JB weld fixed the leak
Bertrand Daoust (06-12-2021)
Process?
Hiya,
please forgive my noobness here… I have a leak on the drivers side oil cooler, pic below. I’m hoping I can fix it without replacing the oil cooler. Would anyone be able to lay out the process? I have some thoughts Below but am wanting to confirm the process for JB weld, etc.
- jack up car
- remove black skirt on bottom of car connected to front bumper
- clean well
- see if I spot why it’s leaking. Bend hoses? Cracked?
now’s the part I need direction on. Once the area is clean do I apply JB weld around where the leak is? Or do I disconnect the hoses, replace the o-rings, apply lock tight, connect the hoses, and then apply JB weld?
wouldn’t applying JB weld to a hose connection glue it into place and make unscrewing the nuts sometime later impossible? The pic below should clarify a bit of what I mean.
- jack up car
- clean well
Hiya,
- jack up car
- clean well
- jack up car
- clean well
Take a look at the WSM and check out seal #9 (at least thats whats shown in MY87-91)
The part number in the MY version I referenced is 900 331 02240 but please do you own checks/or just call Roger. I would clean the area down and inspect to see if there are other leaks WYAIT
Before doing anything it may be prudent to clean the area and see if you can spot anything to indicate that it is the seal that is leaking and not a mechanical failure of some kind.
You might want to check the tightness of that Allen bolt that secures the oil pipes - that joint is not normally a problem child but it may be prudent to unbolt, clean and fit new O rings.
I understand the external cooler was introduced in the 1989 model year- for sure it was present in my late 90S4- presumably designed to remove heat load from the radiator and as I am concerned is a preferable arrangement but its Achilles heel is that there is no induced air flow so not too clever when stuck in traffic on hot days.
