928 Forum 1978-1995
Sponsored by: 928 Specialists
Spanner Wrenches for Oil Line Fittings
Old 03-22-2011, 05:49 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Default Spanner Wrenches for Oil Line Fittings
I bought this wrench set many years ago but could not remember where I got them or find them online again. I just found the receipt and it notes they are Sir Tool P242, designed for Porsche oil fittings. I just wanted to say that they have worked very well for that purpose (and others needing 27, 30, 32, 36mm wrenches), and I'm glad I bought them. Maybe some professional mechanics have a better tool for this job. If so, let us know. Here is the cheapest source I could find for them today.
http://www.toolsource.com/porsche-li...-p-106245.html
Old 03-22-2011, 05:54 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
Thanks Bill,
Good info
Old 03-22-2011, 06:48 PM
ammonman
ammonman's Avatar
I bought this set at HF. Has saved my butt a couple of times for line fittings and other odd and ends. Well worth the $38US plus tax. Sometimes I have to put an extension handle on one or both when breaking fittings the first time, but they seem pretty well made.
Mike
Old 03-22-2011, 07:29 PM
Leon Speed
Leon Speed's Avatar
Bill, what's special about them?
Old 03-22-2011, 07:48 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Well, the heads are thinner and smaller than a large Crecent, which is what most amateurs like me try to use and have trouble fitting in and turning in the tight space. You could use any open end wrench if you already have 27 and 32mm sizes. I didn't. The handles allow easy extension with pipe if needed. However, they are long enough that you can usually use a pinch-together maneuver to break these fittings free unless they are overtightened. The HF set is the same idea, but the wrenches are shorter with less leverage, still they would be useful in other areas where short wrenches are needed. It may seem I'm a little too enthusiastic over a simple wrench, but these just seem to work. The heads may be smaller that other common open ends of this span. I don't know.
Old 03-22-2011, 08:54 PM
Ed Scherer
Ed Scherer's Avatar
FWIW, I've found a set of jumbo crowfoot wrenches (in addition to the more common smaller sizes, of course) to be extremely handy when dealing with hard-to-access situations. Two crowfoot wrenches plus two extensions often allow you to get to things that are pretty damn hard to do any other way. (Like the A/C plumbing connection that's next to and parallel to the receiver/drier; those are actually not "jumbo," though, IIRC).
I have no idea if they're appropriate for oil line fittings (haven't had to do that myself), but I have used them on some other 928 jobs where I wasn't sure what else might have worked.
The set I got is the "V8 Tools V87917". 1/2" drive 20mm, 21mm, 22mm, 23mm, 24mm, 25mm, 26mm, 27mm, 28mm, 30mm, 32mm, 35mm, 36mm, 38mm, 41mm, 42mm, and 46mm.
I got mine from S&J Discount Tools, but they're available from a number of sources. IIRC they're Chinese (which I usually avoid), but it's all I could obtain quickly when I needed them.
Old 03-22-2011, 09:21 PM
Leon Speed
Leon Speed's Avatar
Thanks, that's clear.
Old 03-22-2011, 09:44 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
I agree about crowsfeet on AC fittings, including the ones on the hose ends at the 6E171 compressor (up through 89). Those are near impossible to reach with anything else. Jeez, we probably have a "Useful tools" thread already. I should have placed this there so we don't grow another similar thread.
Old 03-23-2011, 10:01 AM
StratfordShark
StratfordShark's Avatar
+1 on crowsfeet as useful addition to 928 tool collection.
Also work great for the PS line connections at back of the PS pump. There isn't room for a regular socket there.
Old 03-23-2011, 10:06 AM
AO
Supercharged
AO's Avatar
I bought a set of jumbo Blackhawk Gear wrenches off ebay for $60 a few years back. I see they're now a little more than twice that, but still a good buy in mu opinion.
http://cgi.ebay.com/BLACKHAWK-JUMBO-...#ht_894wt_1139
Old 03-23-2011, 10:09 AM
chrly924s
chrly924s's Avatar
Bill, will one of these work on the oil pressure sender?
Old 03-23-2011, 10:26 AM
the flyin' scotsman
the flyin' scotsman's Avatar
Nice set of spanners Bill, price is right to.....sure beats the big NAPA wrenches I got for the 30 and 32mm lines.
wonder if they'll ship to Canada?
Old 03-23-2011, 10:57 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Yes. Just temporarily remove the oil filter for access.
Old 03-23-2011, 11:05 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
According to Toolsource's "International Information", not outside US and PR. And the HF alternative appears to be US only as well.
Old 03-23-2011, 11:12 PM
the flyin' scotsman
thx Bill......they ship right over our heads to Alaska and what is PR?
Need one of those border mail boxes.
Quick Reply: Spanner Wrenches for Oil Line Fittings
