928 Forum 1978-1995
Sponsored by: 928 Specialists
Injectors - choosing the right Design III (and some II info)
Old 10-07-2014, 02:15 PM
  #121
ROG100
Basic Sponsor
ROG100's Avatar
I will probably go with these (maybe): http://www.fiveomotorsport.com/blue-...011-0280150947
I sell the same injectors for $310 for the set (see post #109) and you save $34.36 and would be supporting the 928 Community 8>)
Welcome to Rennlist!
Old 10-07-2014, 02:58 PM
  #122
jcorenman
jcorenman's Avatar
Originally Posted by Kuba
Are we saying that two injectors of the same flow rate (24# @ 3bar) will flow different amounts of fuel at the same pressure depending on latency?
On a lab bench, no. But you don't drive a lab bench, and in a car latency does change the amount of fuel that gets injected.
The difference is that lab measurements (and virtually all of the specs and charts) are based on static flow-- turn on the faucet, measure how long it takes to fill a bucket.
In an engine the injectors are pulsed, and each time the injector is pulsed nothing happens for the first millisecond or so-- that's the latency, also called opening-time, dead-time, or sometimes offset. The total pulse at idle or cruising is only about 2 ms, so it can be a big effect. Change to a different injector with different opening-time and you get a different amount of fuel.
Bosch # 0 280 150 947 is the same as the Ford M9593-A302, good injectors and much discussed in this thread. That's a good choice if that's what the car is tuned for. It is not the right choice for stock chips, stick with the stock 19# injectors and get them cleaned/tested. And if you are using someone else's chips tuned for 24# injectors, then find out which 24# injectors they were tuned for.
And do what Roger says, Five-O are good folks but 928srus are great folks and Roger understands what 928's need.
Old 10-07-2014, 04:37 PM
  #123
Kuba
Kuba's Avatar
I understand now, thanks!
Old 10-07-2014, 09:28 PM
  #124
SMTCapeCod
SMTCapeCod's Avatar
Cool
Originally Posted by Hilton
I'm guessing by now you're aware that there are multiple credible sources of injector flow data, and some of them disagree?
Yes, and now newly-aware of the value of the flow matching services that injector shops offer.
Old 10-08-2014, 01:27 PM
  #125
PorKen
Inventor
PorKen's Avatar
If you are in doubt, send the injectors in after purchase and I will log and make the initial S4.S300s adjustment(s) for you, if needed.
(Injectors must be new or freshly rebuilt and must include a set of lower S4 o-rings - Roger/928sRUs stocks them.)
Just please don't settle for stock or warmed-over 'tuning' based on stock programming...when you could have so much more.
Old 10-14-2014, 10:51 PM
  #126
SMTCapeCod
SMTCapeCod's Avatar
Huh, inadvertent post- carry on. More to follow later. :-)
Old 10-27-2014, 01:17 PM
  #127
SMTCapeCod
SMTCapeCod's Avatar
Do I have it correct that, on the S3, the o-ring diameters are 14mm top and 16.5 diameter lower?
https://rennlist.com/forums/928-foru...ml#post6311562
Got some mischief in the makin'....
Old 10-27-2014, 02:10 PM
  #128
76FJ55
76FJ55's Avatar
O - rings on the S3 are the same size top and bottom. The use the smaller smaller o - ring which matches the Ford installation.
Old 11-10-2014, 10:32 PM
  #129
SMTCapeCod
SMTCapeCod's Avatar
If anyone is interested in injector roullette-
My Ford 24lb blue tops, out of decently running car but should be checked/flow matched:
$__ plus shipping CONUS Actually lets just say SOLD shipped, CONUS.
A bag of 18 of the larger o-rings from FiveO.....SOLD shipped CONUS.
Old 11-10-2014, 11:23 PM
  #130
jcorenman
jcorenman's Avatar
$20 plus shipping CONUS Actually lets just say $25 shipped, CONUS.
A bag of 18 of the larger o-rings from FiveO.....$10 shipped CONUS.
I love roulette, PM sent.
Old 05-05-2015, 12:53 PM
  #131
928mac
928mac's Avatar
I found this page which gives detail on the new ford injector
Is that connector style wrong?
http://fordperformanceracingparts.co...KeyField=12070
Old 05-05-2015, 01:53 PM
  #132
John Speake
John Speake's Avatar
Yes, it's not the same as the Bosch connector used on the 928. You may be able to buy adaptor leads...
Old 06-08-2015, 05:03 PM
  #133
928mac
928mac's Avatar
I don't see that anyone has considered the siemens injectors. whats the reason?
Old 04-27-2016, 08:53 AM
  #134
E30_Dave
E30_Dave's Avatar
Default Injectors
Invader from the planet BMW here !
I just wanted to say a big "Thank you" to you all - This is a brilliant thread, and gave me the inspiration to test modern injectors in my E30 320is.
As you have discovered, quoted specifications for any given injector vary wildly depending on which website you look at - Hence the reason for my chipping in.
In the course of my research, I stumbled across THIS website, and THIS excellent spreadsheet, which is an absolute mine of Bosch Injector Data.
The flow data on this spreadsheet can be checked against those on the Bosch Automotive online catalogue, and all the ones I did check matched perfectly. Flows are in grams per minute (g/min), and the spreadsheet includes all relevant data including design operating pressures, flow @ operating pressure, flow @ 3bar (datum), latency times, spray cone angles, bifurcation, connector type etc etc.. and is very comprehensive. The part numbers covered are 150 , 155 & 156 series, but nothing later.
Also, a big "Thank you" to US Rally team for taking the time to compile such a huge amount of data.
For further reading, see HERE.
I hope you find the information of use.
All the best,
Dave.
Old 08-24-2018, 05:39 PM
  #135
merchauser
merchauser's Avatar
time to bump this thread?
are the latest Ford Gen lll offerings true plug and play, or still need modifications?
what are the current preferred injectors; or is cleaning and flow matching the way to go?
Quick Reply: Injectors - choosing the right Design III (and some II info)
