928 Forum 1978-1995
Sponsored by: 928 Specialists
Intermittent and random stalling of shark
Old 07-26-2013, 11:01 PM
  #31
Landseer
Landseer's Avatar
No, it does not matter (ie, which of the 2 thin injector harness wires you would re-attach to the a) or b) side of the a given injector). They are off/on electromagnets inside, not motors.
Old 07-27-2013, 07:13 AM
  #32
John Speake
John Speake's Avatar
Yes, one of the harness plugs, doesn't matter which one.
Originally Posted by newworld
clarification....when you mention plug multimeter into socket, you mean black and red probes into the fuel injector plug?
Old 07-27-2013, 07:50 AM
  #33
Landseer
Landseer's Avatar
Great puzzles, these cars!
John Speaks has figured them out to the highest degree; John, glad you are here giving guidance to us.
Old 07-27-2013, 10:05 AM
  #34
newworld
newworld's Avatar
New plate 87s4 aut.
While engine running I just lift up passenger side fi harness and engine stalls. Every time.
Tried it 3 times.
I don't think boots are bad I think that whole rear truncated fork area of harness is bad.
Now I am point where I don't trust the whole harness fi.
How can just lifting it stall out an engine. That is reason for hard starts cold and hot.and cut out while driving.
At least the culprit is known. I removed engine and moved harness to windshield maybe there are crusted broken insulation in main harness.
In order to remove whole fi harness from car what is best method? There is a firewall hole I assume. Fi harness is connected to lh or ezk? In passenger footwell?
Old 07-27-2013, 10:07 AM
  #35
newworld
newworld's Avatar
Clarification I removed engine months ago and to remove engine I unhooked fi harness and laid it on windshield I did mover harness around a bit. Perhaps that alone cracked something in there due to brittleness.
Old 07-27-2013, 10:34 AM
  #36
Landseer
Landseer's Avatar
Funny, I have an 85 that did that, even did a youtube video of it.
Then it stopped abruptly after I manipulated another 20 times or so.
I need to disect one of those 32V harnesses to see what, if anything, is going on inside.
Troubleshooting them is awfully empirical.
Old 07-27-2013, 12:39 PM
  #37
Bill Ball
Under the Lift
Bill Ball's Avatar
In my experience the most common location for a short in the injector harness is inside one of the injector boots. However, these cannot be examined without destroying them (you have to cut the boot open). There are replacement connectors with boots. Next most common place is just outside one of the boots where the wires twist and flex, as you appeared to find and insulate. Now, you have noticed lifting one side of the harness seems to create a short and stalls the motor. So, you should try to further isolate the location by manipulating each injector lead individually to see if the short is at one of the injector leads or if it is buried inside the harness trunk, which is less likely since it is so well protected.
Old 07-27-2013, 12:48 PM
  #38
newworld
newworld's Avatar
I do notice some outside charring on the main trunk....but I cannot start engine now. I will try to replace all 4 on passenger side and go from there.
At least I now know why I have been having so many problems.
This explains my sudden stall as well.
Old 07-27-2013, 02:50 PM
  #39
newworld
newworld's Avatar
Land seer I remember seeing that video that reminded me of this problem as I recall u grabbed the wire with pliers etc and it stalled out.
I spliced and soldered all 4 fi plugs new on right side and tried to stall her again. Would not stall.
That means it is the boot, or one of them or several.
My issue is that the boot is really strng and looks really good no crumbling etc...I guess inside is a different story?
I wonder why this happens if the boot is in tact it is there to protect from heat etc.
The other side I flexed harness and can't stall her.
Why is only one side bad?
Maybe it is just a sharp angle in the boot causing copper to touch and nothing to do with heat degradation as the boot is very well intact
Quick Reply: Intermittent and random stalling of shark
