928 Forum 1978-1995
Sponsored by: 928 Specialists
Any experience with "sticking piston rings" on dormant engine?
Old 02-25-2011, 03:41 AM
  #91
Dave928S
Dave928S's Avatar
Your kids will be able to imagine they're swimming somewhere in the Gulf of Mexico next time they use that inflatable pool. Excellent use of a summer product off season
I'll bet you've put parts in the dishwasher when no ones been looking too ....
Old 02-25-2011, 08:06 AM
  #92
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
Originally Posted by namasgt
^^^^ that's what I have suggested, powerful stuff, stinks too so you want to do the cleaning in open air, not inside the garage. I think if he uses it he can just reuse the original pistons and put them in to their original bores, since their worn together.
I already have 7 of my alternate pistons installed. I put them in the original bore locations and am using 1 piston that I was able to get the rings out of in the original location so it should be balanced.
Old 02-25-2011, 08:07 AM
  #93
gbgastowers
Not the dishwasher but the bathtub.
Old 02-25-2011, 08:46 AM
  #94
Imo000
Captain Obvious
Super User
Imo000's Avatar
I don't think that's how ballancing works.
Old 02-25-2011, 09:56 AM
  #95
Lizard928
Lizard928's Avatar
You need to use the original pistons in the original bores.
Old 02-25-2011, 10:14 AM
  #96
gbgastowers
JP Rodkey wrote:"I remember reading somewhere that the engine short block is internally balanced through tolerance control, as one should expect from a high performance precision machine. Within engine family, all pistons and rotating parts are interchangeable and will not affect balance. What I read stated that new factory pistons are ready-to-go and require no balancing because there is, purposely, very little variance including weight(s).
From the WSM, page 13-24a: Since 1980 models pistons and piston pins are paired according to weight. Pistons are weighed with components (piston pins, piston rings, circips).
Piston pins must always remain in the corresponding pistons and must not be mixed up within a set of pistons for one engine. This is important when disassembling and assembing an engine and pistons must be marked if necessary.
If pistons and pins are mixed up, they must be rearranged by checking the total weight.
Weight = 772 g
Permissible tolerance = +/- 4g
In other words, so long as the piston assembly total weight is within that spec range, you are good to go. "
Based on this I think I'm ok-I hope.
Old 02-25-2011, 10:18 AM
  #97
AO
Supercharged
AO's Avatar
What's the worst that could happen? j/k
But that's a great find in the WSM. I need to fwd that to a friend whose working on a motor. Very timely.
Old 02-25-2011, 10:28 AM
  #98
namasgt
namasgt's Avatar
I wouldn't worry about the balance, they should weight the same, I'm just worried about the coating wear on the piston walls. The piston has a coating. If your pistons have most of the coating left, you should be okay.
Old 02-25-2011, 10:45 AM
  #99
Lizard928
Lizard928's Avatar
Weight = 772 g
The pistons and parts were weighed and all put together. The crank was then balanced to that set.
This was my understanding of it when I read that section in the factory manual.
Old 02-25-2011, 10:56 AM
  #100
namasgt
namasgt's Avatar
Colin is right,
I didn't realize you were using rods and pistons from another engine on a different crank. Remember that every thing is weighted, balanced and then the crank is balanced. If you change the weight it will alter the crank balance, but I don't think the difference is going to be a large number.
Old 02-25-2011, 11:22 AM
  #101
blown 87
Rest in Peace
blown 87's Avatar
From what I have seen 928 engines are not really balanced, they are just close and built with a lot of hope.
get a good scale (0.1 gram or better) and weight the pistons and rods, you can make your own mind up on this.
Old 02-25-2011, 06:18 PM
  #102
Roy928tt
Roy928tt's Avatar
It doesn't matter one way or the other, one 928 piston and rod assembly will exchange for another especially 30 years after the fact, there will be no discernable difference. I once had a Mini that had an odd exhaust beat, on dissassembly it had 2 flat top pistons and 2 dished pistons ! It still drove and ran fine.
It is only an engine for goodness sake! and it will do just perfectly after the previous one.
Finally looks like you should be on the home straight Gunar, Good Luck
Cheers Roy
Old 02-25-2011, 06:46 PM
  #103
gbgastowers
Cheers Roy
Thanks Roy,
I have the piston back from the machinist and I will put this last one in tonight. I cleaned the pan of the black stuff again. Wonder where that stuff comes from.
Old 02-25-2011, 07:14 PM
  #104
928 at last
928 at last's Avatar
Default Ageed
I've always used a really accurate scale to match piston weights......but what do I know.
Old 02-25-2011, 09:48 PM
  #105
Lizard928
Lizard928's Avatar
You need to ensure that your pistons, and rod end weights are all roughly the same as the other pistons otherwise you do risk having a shake in the motor, and if too far off could throw everything out the side....
Quick Reply: Any experience with "sticking piston rings" on dormant engine?
