928 Forum 1978-1995
Sponsored by: 928 Specialists
Any experience with "sticking piston rings" on dormant engine?
Old 02-11-2011, 08:23 AM
  #61
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
Originally Posted by Roy928tt
Guys,
As a Qualified Diesel Mechanic I'm going to come out in support of Brad, Diesel is no good for many 'O'rings and seals. Engine seals in petrol or diesel engines are not directly exposed to fuel, only oil, and the oils are not so dissimilar.Caterpillar even make '0'rings exposed to different situations, different colours, nice and simple for the American folks, eh Brad.
Diesel dilution of engine oils is a serious and intolerable situation, to be remedied immediately, as diesel breaks down the lubricative properties of engine oil.
As for cylinders, I always assumed that cylinders were machined parallel, no taper. But you know what assume will do? make an *** out of U and ME ! I'll investigate that one more.
So Gunar is going to soak his pistons and bores in Auto Trans Fluid and see what happens ?
Cheers Roy
Yes- That will be my last gasp effort and if it doesn't work I'll take the engine back out. Of course I might be ruining the bores when I run it to try and free the rings with heat and friction. Gunar
Old 02-22-2011, 06:50 PM
  #62
gbgastowers
Everything I do on this car I have to do at least twice because of mistakes. Got the engine out and the rings should be here tomorrow. Can't wait to see what the problemo is with the original rings.
Old 02-22-2011, 08:28 PM
  #63
Imo000
Captain Obvious
Super User
Imo000's Avatar
How did you know what size rings to order?
Old 02-23-2011, 12:32 AM
  #64
gbgastowers
standard 97mm- Why did I mess up? The motor has the original pistons and rings in it. Next size up was 97.5 which are impossible to find.
Old 02-23-2011, 12:36 AM
  #65
gbgastowers
It's amazing how "not tight" some of these fastners feel as I am taking it back apart after putting it together with correct torque values a couple of months ago. It makes me want to torque a little past spec when I put it back together. Gunar
Old 02-23-2011, 12:48 AM
  #66
gbgastowers
cylinders and heads look as good as when I put it together last month-
Old 02-23-2011, 05:57 AM
  #67
Roy928tt
Roy928tt's Avatar
I am also looking forward to see what you find.
Cheers Roy
Old 02-23-2011, 11:49 AM
  #68
Imo000
Captain Obvious
Super User
Imo000's Avatar
Did you measure the bores?
Old 02-23-2011, 11:19 PM
  #69
gbgastowers
No I didn't. I'll try to.
Old 02-23-2011, 11:30 PM
  #70
gbgastowers
Here is one of the bad rings(piston on right). The piston on the left is out of my other motor. The rings are definitely stuck or worn out. The end gaps are touching. I hope I can get them out without damaging the piston. I plan to do one at a time then put it back to lessen the confusion. Also a picture of the bore which looks good.
Old 02-23-2011, 11:32 PM
  #71
gbgastowers
more
Old 02-23-2011, 11:37 PM
  #72
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Try using a good carb cleaner (not the cheap stuff) on the rings, letting them soak for a few hours. Spray again, and press in with a wooden or plastic tool all around the ring over and over. Get them free without breaking any, and check for wear by checking the end gap on the rings one at a time while they are straight in the bore about an inch down.
Old 02-23-2011, 11:39 PM
  #73
928 at last
928 at last's Avatar
Now might be a good time to soak the pistons in the Acetone/ATF mix for a couple of days. Then go for the removal. Or, if you can get something in there without damaging the piston, try it now. But, if it were me, I'd soak them first.....
Old 02-23-2011, 11:40 PM
  #74
928 at last
And what Wally said......
Old 02-23-2011, 11:42 PM
  #75
gbgastowers
Wally, Thanks for your reply. Are you saying check the old rings for wear? I have bought new ones and plan to clean up piston and install the new ones. Why should I check the old ones for wear? Gunar
Quick Reply: Any experience with "sticking piston rings" on dormant engine?
