928 Forum 1978-1995
Sponsored by: 928 Specialists
Any experience with "sticking piston rings" on dormant engine?
Old 03-05-2011, 11:30 PM
  #136
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
Originally Posted by WallyP
Mobil 1 15W-50?
Some folks like to start with a good non-synthetic and change it after a short time.
Piston ring break-in should be done with varying throttle and hard acceleration. (It helps that you don't have fresh cam noses and bearings to break in at the same time.)
dino= Mystic oil from O'reillys- I read that since the cylinder walls are not fresh, proper ring seating won't really happen (928 motorsports web site on engine break in)
Old 03-05-2011, 11:38 PM
  #137
namasgt
namasgt's Avatar
Doesn't matter if the cylinders are not fresh, you need non synthetic for the rings to seal. If the rings don't seal from using synthetic you may risk oil burning issues and lose some HP. I would use "Torco 10W40 break in oil" to clean the synthetic stuff out and help in sealing the rings (use it for 80-100 miles). And then for good measures use Torco 20W50 TR-1 racing oil (helps in ring sealing) for the next 4-5000 miles.
Old 03-05-2011, 11:39 PM
  #138
Landseer
Landseer's Avatar
It'll be fine.
Time to drive it.
Old 03-05-2011, 11:43 PM
  #139
gbgastowers
I never use full synthetic- Regular dino oil is expensive enough. I tried Mobil 1 in my brand new 1992 full size Blazer and it showed seeping moisture through some of the sealed areas. Of course that was a Chevy.
Old 03-05-2011, 11:48 PM
  #140
gbgastowers
Originally Posted by Landseer
It'll be fine.
Time to drive it.
It's not too drivable now-way out of tune and I really don't know what to do. I think only 3 things can be adjusted.
1st the timing then the idle and mixture. Need the gauges for the mixture. I am thinking about taking it to the local Porsche mechanic for the final tune.
Old 03-05-2011, 11:51 PM
  #141
Landseer
Landseer's Avatar
You will need to have the high ZDDP content oil in this car, regardless.
Did you try moving the distributor (timing) by hand to get the car to smooth out?
(stop the car before the moves, you don't need to get shocked)
Its not uncommon to iterate to the timing setting that works.
CIS mixture --- I don't know --- seems like something you would want to figure out though.
The fact that you could shift up/down --- that has to be a huge positive outcome. Very important at this stage to know it works. That, alone, was as important as it running.
Old 03-05-2011, 11:57 PM
  #142
gbgastowers
here is the data sheet on the oil- I think it's what you said I need. I tried moving the distrib with my wife in the car but can't tell much. I have a timing light I can use to set it correctly tomorrow then I'll go from there. Is the big screw on the front of the throttle body the only way to increase the idle or should I mess with the cable?http://www.newlifeparts.com/newlife/...t815w50shd.pdf
Old 03-06-2011, 12:09 AM
  #143
Landseer
Landseer's Avatar
This has been hashed-out in those oil selection arguement threads here that I usually avoid.
What you want is ZDDP at least 1000 ppm. Most oils have been stripped of most of it, you need to find one that hasn't.
Old 03-06-2011, 11:14 PM
  #144
gbgastowers
Drove it to gas it up with 93 octane. No power under load, stumbles and dies when I let off the gas. I set the timing and pulled a plug that showed too rich so I'm going to back the mixture up a bit. Engine bay is bone dry except for maybe some coolant getting out of the reservoir. The gas tank is leaking a bit since I filled it up. Still need to get it in tune. It felt pretty solid as far as suspension-Kinda like a 30 year old sports car. The steering rack reseal I did is holding up also and the steering feels proper.
Old 03-06-2011, 11:26 PM
  #145
Imo000
Captain Obvious
Super User
Imo000's Avatar
Did you check the compression?
Old 03-07-2011, 12:59 AM
  #146
gbgastowers
No
Old 03-07-2011, 01:24 AM
  #147
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,234 Likes on 1,236 Posts
dont bother checking the compression it has enough to run,
a valid compression test wont be available till you have run it for a few hours under load.
Get the fuel system figured out,
and dont park it in any buildings with the leaking fuel tank,
its one thing to burn the car and a whole other thing to take the house with it
Quick Reply: Any experience with "sticking piston rings" on dormant engine?
