928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 04-18-2011, 01:16 PM
  #781
928mac
928mac's Avatar
Originally Posted by Landseer
Brad, some nice closeups of that porkensioner install would be helpful if you get the opportunity!
OK what did I do wrong? its not torqued yet.
Old 04-18-2011, 01:24 PM
  #782
Landseer
Landseer's Avatar
Thanks!
I have an airpump delete one, but might need to add back airpump.
Just wanted to see an installation up-close. This is perfect because engine is out.
Old 04-18-2011, 01:30 PM
  #783
dr bob
Chronic Tool Dropper
dr bob's Avatar
Originally Posted by the flyin' scotsman
Good stuff. The ISV should be checked as well as the throttle plate bearings.
Done.
Flappy operation and bearing seal should be inspected and the Orings on the intake side plates.
New flappy actuator just because. Old one is fine and in the 'removed original parts' box that stays with the car to subsequent owners. New double-sealed bearings. LocTite on the butterfly screws.
Previously on RL we've had interesting discussion on the orientation of the intake stud shoulders.....whats your thoughts?
Not clear which stud shoulders you are talking about. Link to the discussion?
If you are talkng about the sleeves on the intake mounting studs from the heads, the flared end goes down. There are reliefs around the studs for them, and the flared end guides the position of the rubber intake gaskets. Keeps them aligned perfectly over the ports. Gaskets go on, sleeves next pushed into the gaslkets and the reliaf in the head, then intake, then rubber hold-down grommets, then washers and hold-down nuts.
Old 04-18-2011, 10:12 PM
  #784
dr bob
dr bob's Avatar
Fixed the fuel line connection seepage, finished dressing out the fuel rails, added covers, restored tie-wraps in original colors and positions for everything that was disturbed during intake and cam covers adventure, Changed the oil, and splurged on NEW oil and filter this time...
Lots of clean-up both on the car and the work bay. Tools are mostly cleaned and put away. Floor will get scrubbed tomorrow, car will get a wash-n-clean, and all will be well in my little 928 universe for a few days anyway. Until the little brake project starts later this week.
Old 04-18-2011, 10:17 PM
  #785
UncleMaz
UncleMaz's Avatar
Installed S brake spindles, hubs, rotors, steel lower ball joints and calipers on front of my MY1980. Thanks to Sean (Zoltan944) for the donation (back in '09). My son insists I paint the calipers red. So, the calipers, at least, will be coming off.
Old 04-18-2011, 10:40 PM
  #786
jbrob007
jbrob007's Avatar
Drove my MY86.5 - S3 approximately 276.9 miles... approximately
Old 04-18-2011, 10:46 PM
  #787
1porschenut
1porschenut's Avatar
pulled the transmission and torque tube to install a new one.
Old 04-18-2011, 11:11 PM
  #788
ALKada
ALKada's Avatar
Pulled battery and charged all day. Cleaned ground connections, battery terminals and WOW what a difference. Learned my lesson.
Old 04-19-2011, 12:06 AM
  #789
TheClairvoyant
TheClairvoyant's Avatar
I sealed up the exhaust leak at my cat-backs that happened when the fiberglass wrap worked its way loose over the past few months.
It's nice and quite now. It would have been annoying to listen to during the entire drive down to Sharks In The Mountains
Old 04-19-2011, 12:47 AM
  #790
the flyin' scotsman
the flyin' scotsman's Avatar
The discussion was with Dwayne and his epic intake refresh project.
I too believe the orientation as you do.
Old 04-19-2011, 02:00 AM
  #791
928mac
928mac's Avatar
Well thats it for tonight.
I got the fuel lines sorted and got the cam timing right and the belt on with everything else behind it done.
Im going to replace the rubber hose from the regulator to the cooler with steel braided hose as well
Remember I will not have distributor caps, might go plexiglass
Old 04-19-2011, 09:57 AM
  #792
martinss
martinss's Avatar
Finished leather restoration of removed front seats with Leatherique (5 day job with soak in periods) - results were excellent. Now filling an abrasion on the passenger side in advance of a re-dying.
Old 04-20-2011, 06:23 PM
  #793
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Put a little jesus torque on the rear bearing pins, new hoot struts, and tightened one front wheel bearing..that bearing would have been a 5 minute job, if the bearing cap wasn't designed to survive the apocalypse.
Old 04-20-2011, 06:25 PM
  #794
Speedtoys
Speedtoys's Avatar
Didnt get a new regulator huh...that'll **** you off more than $50 worth later..maybe. (Considering everything else that was done..didnt get a new one?)
Old 04-20-2011, 06:44 PM
  #795
fraggle
fraggle's Avatar
Drove to Quantico VA and back to purge my head of work. Nice.
Quick Reply: So what did you do to your 928 Today......
