928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 03-09-2017, 02:50 PM
  #6931
Mikebte
Mikebte's Avatar
New expansion valve got installed. Baby steps on the AC repair
Old 03-09-2017, 08:18 PM
  #6932
sbirring1
sbirring1's Avatar
After last weekends Greg Brown fuel lines endeavour and new rear brakes, this evenings interior update is easy. Also proud to report I passed the safety inspection and will have plates by end of week.
Old 03-09-2017, 09:58 PM
  #6933
ltoolio
ltoolio's Avatar
Replaced & Torqued both front pinch bolts, remounted lower BH, clutch slave and starter. Not sure if I want to move back to the interior for a little while or get my headers on next...
Old 03-11-2017, 01:07 PM
  #6934
Adk46
Adk46's Avatar
I began putting my shiny new bumper together. Got me a nice new pop riveter.
Old 03-11-2017, 02:39 PM
  #6935
ltoolio
ltoolio's Avatar
Got the headers mounted, with a few of the washers/bolts remaining.
I'm not finding this to be a particularly enjoyable job. Would be easier if I weighed 80 pounds with an additional joint on my arm and the ability to contort myself into weird shapes.
Old 03-11-2017, 03:22 PM
  #6936
Mikebte
Mikebte's Avatar
Installed condenser, new drier, misplaced my new sensors in the garage, filled compressor and installed caps. Found out the AC shop made my hoses the wrong length and I have to return them next week in hopes they can make them correct. Hope they measured, cause I sure did not.
Old 03-11-2017, 03:45 PM
  #6937
Michael Benno
Michael Benno's Avatar
Default Problem solving
fixed floppy passenger mirror and weather proofed wire harness
Found and fixed annoying door/dash rattle caused by loose armrest bolts.
Fixed occasionally returning "always heat" issue caused by leaky vacuum 4way connection at brake booster by using small hose clamps.
Fixed foglight/high beam bug by swapping special relay with standard relay.
Then went for a drive in the rain.
Old 03-11-2017, 09:56 PM
  #6938
Petza914
Petza914's Avatar
Received 6,159 Likes on 3,925 Posts
My 9 year old son and I clay barred, polished, then sealed the paint on the Spyder - took a few hours, but it's silky smooth and well protected again for the next year.
Also removed and painted the door latch catches that had surface rust since I bought the car back in 2015 and were kind of ugly. Also adjusted the driver's side catch upon re-installing so the rear of the door now closes flush - looks much better.
Old 03-11-2017, 10:37 PM
  #6939
Mikebte
Mikebte's Avatar
Sweet car, don't see the soft tops very often.
Old 03-11-2017, 10:44 PM
  #6940
Petza914
Petza914's Avatar
Thanks a lot. It's got lots of upgrades too - big black brakes with 322mm rotors, supercharger, full leather interior with 997 seats, 1,000 watt 8 speaker stereo + sharkwoofer, z06 6-speed trans, etc....
Old 03-12-2017, 01:39 AM
  #6941
Sagres74
Sagres74's Avatar
Got around to installing the 928 decal.
Old 03-12-2017, 04:23 PM
  #6942
Mikebte
Mikebte's Avatar
Started on the fuel line project.
Old 03-12-2017, 06:32 PM
  #6943
Chalkboss
Chalkboss's Avatar
Returned from a trip to Baja to find a dead battery. New big AGM type. Took it to Sears and they recharged it and checked and sent me on my way. So now I'm thinking, where is the drain? Remembered I had last removed glove box, and the switch was wonky. Walked over and checked it, yep! Fixed the wonky switch in 10 minutes. Took the little light 9 days to kill the battery down to 5v. Love the AGMS. Run them down all the way and just charge them up in a hurry.
Old 03-13-2017, 03:02 PM
  #6944
DannyRossa
DannyRossa's Avatar
Default Diagnosed power steering fluid leak
I diagnosed a bad power steering hose leak on my 1984 porsche 928 hose
Also this is my first post on Rennlist
Old 03-13-2017, 03:11 PM
  #6945
Petza914
Petza914's Avatar
Welcome and good job. Those PS leaks are the cause of some of the 928 engine fires you see from time to time, so good you resolved it.
Quick Reply: So what did you do to your 928 Today......
