928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 02-27-2017, 06:14 AM
  #6901
DuncanF
DuncanF's Avatar
Originally Posted by Snark Shark
I believe mine broke in the same way, since the trip odometer was stuck at "000". Although after seeing the condition the gear material was in, I doubt it would have lasted much longer even if the reset button was never used.
Same here. Odo gear was my job last weekend and, yes, it was on the kitchen table.
This weekend end was the blower motor. The used one I put in a few months ago had completely seized so I put the old one back in having, hopefully, sorted out the poor connections that were stopping it from running.
Old 02-27-2017, 12:49 PM
  #6902
bureau13
bureau13's Avatar
Fixed my passenger side mirror that had come loose, and fiddled with my speaker wiring at the amp, which was starting to break up again.
Old 02-27-2017, 10:00 PM
  #6903
Hymodyne
Hymodyne's Avatar
installed hard fuel lines from injectors and injector seals.
Old 02-28-2017, 08:44 PM
  #6904
Hymodyne
Hymodyne's Avatar
oil filter came in the mail and pep boys had a distributor cap. Rotor should come in tomorrow.
Old 03-01-2017, 05:23 PM
  #6905
Mikebte
Mikebte's Avatar
Got some of my AC stuff in the mail. Still waiting other parts.
also got hose to repair injector hoses
Old 03-01-2017, 08:11 PM
  #6906
Mikebte
Mikebte's Avatar
The aluminum ball joints now have something to fear. Replacements have arrived.
Old 03-02-2017, 04:48 AM
  #6907
G.P.
G.P.'s Avatar
Started her up for the first time in about 6 weeks, after being busy doing some re-plating work in the engine bay.
Looking like she should have another 10 (seat of the pants) horsepower
There's still a couple of things to finish off.
Old 03-02-2017, 10:15 AM
  #6908
Taguid
Taguid's Avatar
Talking
Very nice! My engine has a very similar paint scheme.
Old 03-02-2017, 12:58 PM
  #6909
soontobered84
soontobered84's Avatar
This dash message showed up on my 89 and sure enough, the fuel gauge was non-functional. I determined that the fuel gauge sensor was the culprit, so I removed the sensor, disassembled it, and found that the internal fuel level slide was stuck at the very top of the assembly. I freed the slide and reassembled and reinstalled the fuel level sensor.
Unfortunately, I was called away to work before I got a chance to test it, but I feel confident the problem was fixed.
Old 03-02-2017, 03:38 PM
  #6910
Mikebte
Mikebte's Avatar
Compressor showed up today
Old 03-02-2017, 07:43 PM
  #6911
G.P.
G.P.'s Avatar
Great minds think alike, even on different sides of the planet!
Old 03-03-2017, 07:04 AM
  #6912
The Forgotten On
The Forgotten On's Avatar
Put new spark plugs in the 81, replaced a bad H4 headlight (for the wrong country though :banghead) and replaced the all metal filter in the 89's provent with a normal one.
Old 03-04-2017, 04:08 AM
  #6913
Bucko74
Bucko74's Avatar
Put the right front coilover back together after strip and refinish. I like the colour scheme.
Old 03-04-2017, 08:03 AM
  #6914
curtisr
curtisr's Avatar
Me, too!
Old 03-04-2017, 08:24 PM
  #6915
Mikebte
Mikebte's Avatar
Changed my oil today. After the oil change I started removing A/C parts for retrofit and repairs. Also found my alternator was previously replaced and I need to get the screws the hold on the cooling duct.
Also noticed I need the hats for my injector hoses.
PO replaced with clamps on the top half.
Quick Reply: So what did you do to your 928 Today......
