Automatic Shift Knob Question
#46
I have the stock T-handle from my 82, if it will work you're welcome to it. I just need to get something else.
#47
Here is a pic of the Jager shift ****. I remember bagging it up and putting up somewhere. Along with the MOMO matching steering wheel. Anyway , if it works for you Shawn, let me know. Kevin
#48
Yeah, that's exactly the kind of thing I'm looking for, but my interior is black. I'd be hesitant to dye it, because I think it would eventually start coming off on my hand.
#49
Hey Shawn,
You can look at this listing. Might be what you need.
http://www.ebay.com/itm/1981-Porsche...52d7a7&vxp=mtr
#51
Thanks, Bilal. I saw that one and it looks kind of weird. My shifter has a hollow rod with a 1/2" slot at the top, and the lock button protrudes about 1/4" above the top of the shaft. The T-handle button has a fin or vane that slides sideways into the slot, depressing the lock button about 1/4" and allowing the shifter to move. I'm not sure why this shifter has a long button shaft.
In looking around, it looks like the C4 Corvettes have the same setup as the 928.
#52
So the entire shifter would have to be dismantled?
#54
[QUOTE=Shawn Stanford;11671851]...I'm not sure why this shifter has a long button shaft.
I remember reading a post a long while back where someone tied in pressing the button to the kickdown switch activation.
#55
So, I found some shifters on eBay that should work, now I just need to make a decision.
This one is small and simple.
This one has a nice pistol grip shape.
Very simple, retro, and cool.
Red, to match the car.
And there's always room for some fun!
#56
The sick speed, IIRC is a push to shift design which is nice. I think you may want to confirm the rod diameter though. I thought the machined parts were nice, but found the ball a little too large and too retro. YMMV. The "pistol grip" one looks a lot like some of the more recent factory shifters. I tried one of the factory ones, but wasn't happy with the way it functioned. I had a plain, all-aluminum version of the top one, worked adequately but again the rod diameter was just a little off and it was pretty tall when assembled . The set screw worked OK and a wrap of friction tape probably would have resolved it.
#57
Thanks, Steve!
