928 Forum 1978-1995
Sponsored by: 928 Specialists
shift coupler boot
Old 07-24-2010, 05:14 PM
tombtaylor
tombtaylor's Avatar
Default shift coupler boot
Does anyone know of how to get the shift coupler boot over the shift coupler???? I've tried everything but KY Jelly...Help!!!!
tom Taylor
Old 07-24-2010, 05:19 PM
ROG100
Basic Sponsor
ROG100's Avatar
Use some washing up liquid/soap for lubrication.
If that fails break out the KY.
Old 07-24-2010, 05:37 PM
Jadz928
Jadz928's Avatar
Lube up the inside only to allow you to still get grip on the outside.
Skip the soap... use silicone lube.
Old 07-24-2010, 05:59 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,548 Likes on 1,232 Posts
Slit it with a box cutter like you're gutting a fish, then stretch the front of the boot over the flange on the shift rod and secure it with a ziptie. Life is too short to deal with that degree of PITA.
Old 07-24-2010, 06:39 PM
GlenL
GlenL's Avatar
Exactly what I did.
Might be easy to do with the TT out of the car. From underneath? I'd almost skip the whole thing but once you've got the part you might as well use it.
Old 07-24-2010, 09:30 PM
Mike Frye
Craic Head
Mike Frye's Avatar
These are one time use.
Old 07-24-2010, 09:48 PM
Ducman82
Ducman82's Avatar
thats what i did.
Old 07-24-2010, 10:44 PM
Hilton
Hilton's Avatar
I slid it over on a couple of cars - took a few goes, and its important, like Jim says above, to keep the lube off the outside so you can get a grip on it.
Push it over lop-sided, so that it goes past one of the humps on the side of the coupler first, then with some twisting movement the other side will pop over fairly easily.
Old 07-25-2010, 02:55 PM
tombtaylor
tombtaylor's Avatar
after spending an hour & a half yesterday trying to work the boot over the coupler....today I made a tool & with the help of some vaseline....it took about 5 minutes to get it on...just hooked it behing the lip inside the boot & pulled it over...
Old 07-27-2014, 12:53 AM
granprixweiss928
granprixweiss928's Avatar
Ive installed my new bushings in the coupler and a new boot, mine was torn at the the selector shaft end.
I have a hard time getting the end of the boot on the flange of the shift shaft.
Ive tried some car washing soap to lubricate it but then I cant get any grip,
ideas?
Old 07-27-2014, 02:55 AM
Ad0911
Ad0911's Avatar
Some tips here:
https://rennlist.com/forums/928-foru...l#post11290246
The boot can be stretched quite a bit. Worked fine for me.
Old 07-28-2014, 07:56 PM
SeanR
SeanR's Avatar
I hate putting that boot back on. Absolutely hate it. I might need to make a tool like the one above to make it easier.
Today, I was doing a coupler on a mid mount turbo car and if you thought it was a pain in the *** before, try one of these.
Old 07-28-2014, 10:26 PM
granprixweiss928
I left it for the night and attempted again in the morning. hands still sore from the previous night attempts. I applied some washing soap to the flange...not the boot and tried again, working from the top and pushing the whole boot forward, I managed to get the lip over the flange and then work it around the sides to the bottom. Got it on! took me about another 15 min. so happy it didnt take me longer.
Quick Reply: shift coupler boot
