R-12 Refrigerant Replacements?
Almost Deleted
Has anyone tried one of the r-12 refrigerant replacements on the market? I've seen quite a few marketed on other various car forums/websites. Several even quote the ability to act as a drop in replacement, w/o retrofitting. Specifically, Freeze-12 from Johnson's Chemicals make this claim. [even though legally you must completely remove all the current refrigerant before you charge the system with something different].
Thoughts?
http://www.freeze12.com/
http://www.aa1car.com/library/tr497.htm
Thoughts?
Chronic Tool Dropper
Are you the caretaker of the refrigeration forever more in the life of this car? Did you fix the leak(s) that caused the recharge need? Generally, by the time all the leaky o-rings and seals are replaced and the drier is changed, the only difference between the marginal replacements and mainstream R-134a is changing the compressor oil out for POE. M<y too sense.
IIRC, your local 928 parts supplier knows where there is R-12 available too.
Almost Deleted
The seals and o-rings will be changed. I didn't plan on swapping the receiver/drier unit.... hence the question.
I'm certainly not opposed to migrating to R-134a. I see 928gt carries both an OEM Porsche receive/drier and the URO equivalent. Are there any deltas [except price]?
DuraCool
Thoughts?
Thoughts?
I don't care if a '95 Suburban or Jimmy goes up in flames, but the Porsche
The compounds are very similar to Butane (the stuff in yer bic lighter), so if there's a leak, and no airflow, and a loose plug cap......
Rennlist Site Sponsor
As a general rule, a commercial A/C shop won't touch a system with anything other than R-12 or R-134a.
R-134a is $7 a can at Walmart and $5 a can at our local Big Lots...
Rest in Peace
I've used the DuraCool in my GM products for years now with very good results. I really wouldn't consider using it in my car......
I have used autofrost in mine with no problems (decided to use this rather than r12 for finding a leak). It is a blend, that actually seemes to work better than r12 and can be added to r12. Head pressure was less and seemed much colder. Also as stated above shops will not evacuate a 'compromised system'. Luckily I have all equipment to do mine. I have since cleared system and am now with r12 after replacing bad condensor. I used this product for 3 years with no problem.
Rest in Peace
Specialists carries the 944 drier, a functional replacement for the 928 drier. It's a fraction taller and a fraction smaller diameter, so a shim at the clamp and a few inches of plastic spiral cable wrap around the PS cooler piping underneath will be needed. It's relatively inexpensive, has the correct dessicant for R-134a, and has s sight glass that may help with diagnosis if the system underperforms. Replacing the drier is a must i the system is open to atmosphere or the refrigerant and oil are changed.
My 10yo R-134a conversion in my S4 will freeze fingers on the wheel. With freeze switch jumped, it cranks 18ºF air at the center vent at freeway cruise speeds, 90+ ambients, fan on 2, black car with no tint in L.A. area. Driving today, the outside temp display said as high as 109º in Pasadena and over into the SF valley. I think it only got to 104º officially though. RH less than 50%, fresh air vent cycling with cabin slider set at 72º. While there's no simple cure for a heat-soaked car, the system certainly has the capability needed for my driving pattern here. Don't be afraid of a good conversion.
Almost Deleted
All, thanks for notes. Dr bob, if you're getting that sort of performance in a similar climate, then I'm sold. A working ac is a must have around here for 7 months out of the year
I'm not guaranteeing that all other conversions will give the same results I get. Justletting you know that the system performance is available. You have much higher humidity for instance. Yesterday it was about 40% RH at 98F, so dew point was probably in the mid 50 degree range. The system has to work a lot harder to drop temps below dew point of the air in the evaporator. For many systems this might be the lowest available evap temp. It will get colder in recirc mode as moisture in the cabin air is removed. Don't open any windows, and try not to exhale!
Almost Deleted
John,
If you are replacing the O rings anyway, you really should replace the drier. Especially since there is an O ring on either side of it. From that point, you just need to unbolt it from the coil
Almost Deleted
Sounds good... might be something else I add to the upcoming tech session [if time permits]
