928 Forum 1978-1995
Sponsored by: 928 Specialists
Twin Turbo 928 fixed and back out there terrorizing the streets!
Old 10-21-2016, 12:41 PM
  #1336
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,553 Likes on 1,234 Posts
There is a bit of a hole between 60 and 80 mm in the Normaclamp and Gemi offerings used on the 928.
Old 10-22-2016, 07:32 AM
  #1337
ptuomov
ptuomov's Avatar
I don't know what to say, Rob! Clamp-OCD has an ICD-9-CM code now? ;-)
Seriously, though, have to admire how systematically you're approaching this 928 thing.
For the turbo car, the clamping problem on the low pressure side of the compressor is mainly related to the size and fit, as there's no room and the clamps can't rub anything. On the high pressure side, there's the thermal expansion issue as the temperature fluctuates considerably, and the clamps can't cut into the silicone connector. And of course there's not room.
Old 10-22-2016, 04:52 PM
  #1338
Imo000
Captain Obvious
Super User
Imo000's Avatar
300lb zip ties for the low pressure side?
Old 10-22-2016, 05:40 PM
  #1339
DKWalser
DKWalser's Avatar
Oh, be serious! He wants it to be serviceable. You cannot do that with zip ties. Twist ties are the obvious answer.
Old 10-22-2016, 05:44 PM
  #1340
Imo000
Captain Obvious
Super User
Imo000's Avatar
There are zipties that are servicable. Or use CV boot clamps.
Old 10-23-2016, 01:17 PM
  #1341
ptuomov
ptuomov's Avatar
Default Connections
On the low pressure side, the main things that those clamps have to do are maintaining location and hold down the heat shields without cutting into the silicone. On the high pressure side, there's the pressure force as well. The high pressure side is 2.5"-2.75" by the way...
Old 10-23-2016, 10:50 PM
  #1342
Rob Edwards
Archive Gatekeeper
Yes, ICD-10 is F60.5, But it gets worse:
Turns out Gemi has a 50-70 mm clamp that might work for 2.5-2.75" applications, looks like they're narrower than the ABA you showed above, if that would help with the space issue (?).
Old 10-25-2016, 05:07 AM
  #1343
ptuomov
ptuomov's Avatar
Default New pump bracket
The new oil pump bracket is in. This one fits clean with an engine that has an oil pan spacer and a mini starter. The main thing is running the oil lines.
Old 10-30-2016, 01:45 PM
  #1344
ptuomov
ptuomov's Avatar
Default Sensor fusion
The sensors are being set up on the motor, dyno being set up for the sensors, and the turbo speed gauge will now have a toggle switch to show each side reading, etc.
Old 10-30-2016, 10:01 PM
  #1345
ptuomov
ptuomov's Avatar
Default This is what I was doing when John was fabricating the lines
go cubs!
Old 10-30-2016, 10:03 PM
  #1346
ptuomov
ptuomov's Avatar
Default Turbo oil sump scavenge lines
Here's how the new lines are run. The routing has to be a little different because of the oil pan spacer:
The basic scheme is the same as before. There are two cylinder shaped sumps, one per turbo. Those sumps serve two functions. First, they allow the air to separate from oil into larger bubbles. The turbo oil drain outlet has a fair bit of foam. Depending on conditions, oil and air move up/down and from/to the BMW air oil separator drain line. The drain line has to be large for that reason, and will not have a check valve. Under most (possibly all) conditions, the oil pump capacity is large enough that it will pull, in net, air out of the BMW air-oil separators, but the system will operate even if the pump capacity is below that threshold. Just some defensive design there. Second, the sumps allow oil to accumulate in one of the sumps in extreme cornering.
Old 10-30-2016, 10:06 PM
  #1347
ptuomov
ptuomov's Avatar
Default The MAF, box, and screens
The new box design should really help with feeding the MAF housing from all sides. Big a$$ hole right there, secure connection, and coarser screen.
Old 10-30-2016, 10:11 PM
  #1348
ptuomov
ptuomov's Avatar
Default Wastegate control
This setup will have two solenoid valves. The solenoid valve will send pressure to closing side of the wastegate diaphragm. This will allow us to control the boost at high intake and exhaust manifold pressure levels. The lines are flared hard lines, no temperature issues ever:
(iPhone user interface for posts that have images is completely useless on this site.)
The intake manifold pressure is connected to the opening side of the wastegate diaphragm as in the simple system without any electrical valves. The solenoid valve is plumbed on the closing side. It pulses pressurized air from the plenum box into that opposite side of the diaphragm. If the valve provides full open, that is, the full pressure to the opposite side of the diaphragm, then the forces on the both sides of the diaphragm cancel and the only net on the gate are the exhaust back pressure trying to open it and the spring holding it closed.
The EB2 controller is similar to the standard PID-controller, so although the tuning parameters will likely have to be changed for this new "passive-aggressive" gate settings, I don't anticipate any long-term control algorithm problems there.
Old 11-02-2016, 04:00 PM
  #1349
ptuomov
ptuomov's Avatar
Default Need more thermocouples...
More more more
Old 11-02-2016, 04:17 PM
  #1350
Rob Edwards
Archive Gatekeeper
8 temp, 5 pressure and 1 delta-P transducer? Whole lotta data, wow. The pressure drop across the intercoolers is assumed to be the same side-to-side? Why not delta-P and the two temps on the same intercooler?
Chris approves, but:
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
