928 Forum 1978-1995
Sponsored by: 928 Specialists
1987 Porsche 928 S4 No Spark
Old 01-24-2010, 10:32 PM
rhylan1961
rhylan1961's Avatar
Talking 1987 Porsche 928 S4 No Spark
My shark sat for about one month with the battery unhooked while I changed the time belt, water pump and all related part. Rotors and caps are new. I have power to the coils on +. The fuel pump relay will not activate but I can jump it with a jumper wire and it works. Just not spark on the wires. I have a viper 160vx remote start with keyless entry. Could it be a problem or is it the Crank Pos. sensor? Any help will be greatly appreciated.
Old 01-24-2010, 10:35 PM
Dan87951
Dan87951's Avatar
Does the rpm needle bounce when starting? If not check crank sensor.
Old 01-24-2010, 10:47 PM
rhylan1961
rhylan1961's Avatar
No needle movement. Whats funny is that the car ran great before repairs. The Crank sensor is 23 yrs old. Do you think that could just go bad sitting?
Old 01-24-2010, 11:20 PM
rhylan1961
rhylan1961's Avatar
I s there a easy test for the Crank sensor?
Old 01-25-2010, 01:42 AM
Lizard928
Lizard928's Avatar
If it is original then it should be replaced. But first relay relay relay.
Old 01-25-2010, 02:41 AM
Larry928GTS
Registered User
Larry928GTS's Avatar
Make sure that those smaller wires at the battery positive terminal are making a good connection.
Old 01-25-2010, 06:42 AM
Dan87951
Dan87951's Avatar
if the tach needle isnt bouncing while cranking that tells me no signal at crank sensor.
Old 01-25-2010, 07:27 AM
rhylan1961
rhylan1961's Avatar
Default Porsche 928 S4 No Spark
I have a new Crank sensor ordered. I will check relays. You know whats funny is that when you crank the car the doors lock and unlock. I don't understand this. It has never happened before. I hope my viper remote start is not a problem. It is also keyless entry.
Old 01-25-2010, 08:25 AM
fraggle
fraggle's Avatar
I'm going to vote viper problem because of the weird door locking.
Old 01-25-2010, 08:38 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,254 Likes on 1,247 Posts
replace the fuel lines if you have not already done this
I vote for the alarm causing problems
Old 01-25-2010, 04:46 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
I have a Viper alarm that causes the doors to lock too occasionally. Aftermarket alarms are crap IMHO. Mine has been sitting for a month too and I'm sure it's going to do the same thing as yours.
Old 01-25-2010, 07:15 PM
rhylan1961
rhylan1961's Avatar
I talked to Best Buy about my Viper system They said that nothing in the Viper system will stop the car from starting. They did say that the factory defaults came back since the battery was disconnected so long. They would have to reprogram the system after I go the car running. So @ this point I'm hoping it is just the crank position sensor. They said that the viper thinks the car is running so it tries to lock the door. Thanks again for everyones help. God Bless.
Old 01-26-2010, 08:17 PM
rhylan1961
rhylan1961's Avatar
Turned out to be the crank position sensor. Now I have a miss in the engine. Could it be I fouled out the plugs with all of the attempts to start it?
Old 01-26-2010, 08:24 PM
fraggle
fraggle's Avatar
I was just going to post that it's the blue/white wire on W23 on the cel - unplug it to isolate possible interior shorts from the cpu's - but I guess it's irrelavent.
How long has it been down? Your fuel might be a little stale.
Old 01-26-2010, 09:30 PM
Dan87951
Dan87951's Avatar
Change the plugs to be safe. Also Check your coil wires. If your wires haven't been replaced yet my vote is on them or plugs. Good Luck.
Quick Reply: 1987 Porsche 928 S4 No Spark
