928 Forum 1978-1995
Sponsored by: 928 Specialists
Garage clean out - OEM 928 cove,r Kempf tool kit, window switches, etc...
Old 01-18-2010, 09:33 AM
aircooler
aircooler's Avatar
Default Garage clean out - OEM 928 cove,r Kempf tool kit, window switches, etc...
Hello All,
Ahh! I deleted the text of this post somehow, and had to re type it all.
I was cleaning out the garage and have listed some 928 "stuff" on ebay.
In accordance with rennlist rules, all these items have a buy it now price.
Porsche 928 S4 GT GTS factory car cover "OEM accessory". start $100 - BIN $150
EBAY LINK - 928 COVER
Kempf timing belt tool kit (with fly wheel lock) SOLD
EBAY LINK - KEMPF TOOL KIT
1 "new in the bag" Bosch fuel injector (fits S4, mabe other?) SOLD
928 engine oil pan gasket. Heavy rubber re-usable type. SOLD
GTS air intake tubes. Kind of rough. One is 7/10, the other 5/10 condition. $25 + shipping.
2 "new in the bag" 928 window switches. I never got the chance to install them. SOLD
New air line kit for the S4 (maybe others). Never installed. These were sold by a rennlister a few years ago, but I forget who? SOLD
I have to go through a few more boxes to see if there is anything else worth while, or that I would part with.
Cheers,
Michael
Old 01-18-2010, 09:42 AM
mcholdfast
mcholdfast's Avatar
I'll take the window switches and pan gasket if you'll sell them off eBay.
Old 01-18-2010, 10:01 AM
mcholdfast
mcholdfast's Avatar
Ok, I'll play. Who's Al and what has he done with my switches and pan gasket?
Old 01-18-2010, 10:22 AM
aircooler
aircooler's Avatar
HA ha, Michael the switches and gasket are yours if you want them. I'll get back to you around lunch. I have 2 kids screaming for breakfast right now.
Old 01-18-2010, 10:26 AM
Glenn M
Glenn M's Avatar
I will take the air line kit.
Thanks,
Glenn
Old 01-18-2010, 10:29 AM
mcholdfast
mcholdfast's Avatar
Thanks, might as well throw in the injector too. As long as I have a spare, I'm sure I'll never need it. Well, that's the way it usually works anyway.
Old 01-18-2010, 11:08 AM
Tom in Austin
Tom in Austin's Avatar
I'll take the GTS air tubes if shipping to Austin, TX USA 78704 isn't prohibitively expensive ...
Old 01-18-2010, 11:22 AM
BIMMERMIKE
BIMMERMIKE's Avatar
Default In Cambridge?
Hi Michael have you moved to Cambridge? Much closer to Hamilton now for cruises.
Old 01-18-2010, 11:40 AM
leperboy
leperboy's Avatar
That is the Mark Robinson vacuum line kit and the rubber elbows are not heat tolerant. After a few hundred miles, the underhood temps will crack and break them. I have the same lines and had to go in and swap all the rubber about six months after installing.
Roger sells better replacement rubber boots as a kit to fix this.
Matt
Old 01-18-2010, 11:43 AM
Cosmo Kramer
Cosmo Kramer's Avatar
Hey Michael, I sent you a PM!
Old 01-18-2010, 11:49 AM
linderpat
linderpat's Avatar
Received 2,250 Likes on 1,254 Posts
Glenn - watch out for the connectors on the air line kit. I believe that was a Mark Robinson kit, which routed more efficiently than the stock kit - good set up (I put it in my prior shark), but the connectors had a habit of dry rotting in a season or two. I did a search but can't find the old thread, so maybe someone else will chime in.
Old 01-18-2010, 12:26 PM
Jerome Craig
Jerome Craig's Avatar
They do... I have the that same kit but found out about the connector problem a while back. I've ordered new connectors from DR, but Roger has them too. Several listers have had to re-do their intakes...and that's not a lot of fun.
Old 01-18-2010, 12:51 PM
the flyin' scotsman
the flyin' scotsman's Avatar
If the window switches, vac. lines and injector remain available I'll take them.
Old 01-18-2010, 01:05 PM
antsmands
antsmands's Avatar
I'm interested in the Kempf kit!
Old 01-18-2010, 02:18 PM
Glenn M
Glenn M's Avatar
I also ordered new elbows for the other kit I have.
Glenn
Quick Reply: Garage clean out - OEM 928 cove,r Kempf tool kit, window switches, etc...
