Ignition Switch Not Turning
#32
The colors coded on the diagram do not all match the ones I have.
I have a Yellow wire
2 Black Wires
2Black/Yellow Wires
1 Gray Wire
2 Red Wires
1 Red/Black Wire
2 Black Wires
2Black/Yellow Wires
1 Gray Wire
2 Red Wires
1 Red/Black Wire
#33
ignition switch connector harness -- HELP
Okay. I took the plastic piece that holds the pins in, aaprt and they all just fell out.. Unfortunatly I do not have a manual yet, so is there anything I can find that shows the correct placement that the pins should insert?
Also, I obviously notice the yellow wire, but where is the jump start I should test it on?
