engine smoke, 1982 928sl
since changing my oil, whenever i get into the gas, it is blowing out a lot of smoke out of exhaust, not during normal driving,filled to mark on dipstick, car does stayed parked a lot, coincidence or something i need to check out
And the smoke is bluish? Sounds like it is over filled. Unless you meant to say, "oil between marks" which is the way the sticks are marked. My stick has a rubber thingy at the top which compresses slightly forming a seal into the sleeve. Could this have moved upwards or compressed with age? Maybe this plus filling to the top line is causing an overfill situation. YMMV
Team Owner
it might be a good time for a compression check, also spark plug inspection
i will check out the dip stick when i get in,30 days on river, sounds like a good place to start, car only runs about 3 thousand miles a year, i changed oil with Pennzoil and the recommended weight,my son drives car,do not know if he added any oil, thanks for help
