928 Forum 1978-1995
Sponsored by: 928 Specialists
engine thrust bearing repair
Old 11-04-2009, 04:30 PM
88porsche928
88porsche928's Avatar
Default engine thrust bearing repair
is their any repair for engine thrust bearing failure? or is the entire engine garbage?
Old 11-04-2009, 04:58 PM
blown 87
Rest in Peace
blown 87's Avatar
If it got into the block it is done.
Old 11-04-2009, 05:04 PM
Hilton
Hilton's Avatar
uh oh.. this doesn't bode well.
There are a couple of posts here about repairing blocks that have have thrust bearing failure.
Someone (I think Imoo?) mentioned a Candaian 928 that had a repair done by machining out the damaged part and using an insert?
However, probably much $$ compared to just getting a new engine (warning: make sure the engine is good - that means buying from someone who will warranty it, not just someone who says "ran great when I pulled it")
Old 11-04-2009, 05:06 PM
mark kibort
mark kibort's Avatar
doesnt this mean that the thust bearing is damaged? cant you just replace the thrust bearing, and check the crank to see if it is damaged as well?
Old 11-04-2009, 05:08 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
That’s not so.
As long as the block isn’t cracked it’s fixable but it won’t be cheap or easy. I’ve seen one repaired and it worked flawlessly. The damaged area was machines flat and a 2 piece spacer was installed behind a new (early 32V) thrust bearing. Apparently the early thrust bearings have a larger surface area and are better over all, especially for a repair like this.
Old 11-04-2009, 05:21 PM
blown 87
Rest in Peace
blown 87's Avatar
If you say so, but I would never trust a block that the crank had gotten into.
By the time you spent all the money for machine shop stuff, you might just have more money into a questionable block than a good used short block would be.
Originally Posted by Imo000
That’s not so.
Old 11-04-2009, 05:23 PM
cali4sun
cali4sun's Avatar
Just had my flex plate checked recently wanted to avoid this scenario....Best of luck on repair!
'89 S4 GP White/Black
'76 912E Silver/Black sunroof
Old 11-04-2009, 05:38 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
If you do all the work, besides the machining, the cost of maching is not that much (3-4hrs). They only have to touch one side of the journal. I have no reason to beleive that it will not be as stong as it was before. AND at the end, you'll have an engine that has all new gaskets too. If you buy a good used engine, the gaskets will probalby be old so you would want to re seal it anyways and that will add at least $350 to the cost.
The original question was if it's fixable and I'm saying it is. Is it practical or cost effective, well that depends but it certainly is doable.
Old 11-04-2009, 06:15 PM
G Man
G Man's Avatar
Aw heck...just smear a bunch of JB weld over the damaged part of the block and jam a new thrust bearing in there before it sets up and you'll be good to go!
Old 11-04-2009, 06:24 PM
blown 87
Rest in Peace
blown 87's Avatar
Don't they usually crack really bad when this happens?
Most of them I have seen do.
I will say that you may be right, on some blocks it may be possible to save them, I am just not going to do it.
And, you are also right, that was not his question.
Old 11-04-2009, 06:38 PM
Tom928
Tom928's Avatar
My $0.02 worth.
Even if it were fixable - reliability would be something I would be very concerned with. I have thought of what I would do in this situation and decided if it did, I would buy a used engine and rebuild it.
Others may disagree, but I would not want to worry about how reliable the fix would be.
Good Luck,
Old 11-04-2009, 06:50 PM
docmirror
Shameful Thread Killer
docmirror's Avatar
We're not sure yet it's TBF. It could be 2/6 rod bearing. The engine is seized hard. Need to get into the crankcase to find out for sure. I wonder if there's a way to snake a borescope down the oil filler area after removing the baffle to inspect the crank thrust webbing?
Old 11-04-2009, 06:59 PM
soontobered84
soontobered84's Avatar
Someone local Doc?
Old 11-04-2009, 07:46 PM
blown 87
Rest in Peace
blown 87's Avatar
I think I could get mine in through the oil drain and be able to see it, but I have never tried to.
I have a 928 in the shop and it is getting a oil change tomorrow, if my dumb *** does not forget, I will try to see if I can see the rear of the thrust bearing area.
I will post a pic in a minute of the one I have.
Old 11-04-2009, 09:24 PM
88porsche928
i wasnt driving it hard and the rpms went high i dont know how it happened. heres what happen one day i got the water pump and timming belt changed shortly after I changed the oil/filter. next day after i brought the car back it started cutting off at low rpm / at stop lights. while driving back to the mechanic the car died without making any sounds on the interstate, i was driving slow but the rpms where above 1,000. I could not start the engine becuase the battery was drained again, I told the mechanic to drop the oil pan and also check out the thrust bearings, what else should I ask him? I took this car to performance independant porsche in san diego, the guy has alot of experience with porsches and has no complaints against him. he said he doesnt know what could have caused it.
Quick Reply: engine thrust bearing repair
