Behr radiators suck
#31
Basic Site Sponsor
Basic Site Sponsor
Mark--
Let me know what you need for it. I'm not in serious need at the moment, but time is not on the side of my original. I can take yours, add new tanks, my coolers, and maybe have some good years from it yet. There's also another local whose car is disabled due to failed radiator and concurrent cash flow problems. It will get him on the road if I can get it repaired using the excellent tips shared so far.
So far (knock on plastic...) mine has done really well with just the regular (annual) coolant changes. Use the right coolant, distilled water, change regularly, and there really isn't much that should go bad with the core itself. Right? Passed 90k this week. The 'new car' aura is diminishing just slightly.
I've got a pretty good stack of used radiators sitting around. If you need one or two...to play with....come by and get it/them. Mark Anderson used to take them and rebuild them, but doubt he wants them, now that he sells his aluminum ones.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#32
Administrator - "Tyson"
#34
Cool info on Carl's setup.
I didn't have any problems with fitment on the C&R because I also went with sharkblades at the same time. I found I can do a timing belt job without even pulling the rad!
#36
Chronic Tool Dropper
I'll be down in the neighborhood late next week hopefully to get some painted parts from Big Chris. I'll stop by for a visit.
#37
dr bob, sounds like you have a better option locally. I may hang this thing on the wall as decoration. Meanwhile decision made, I'm calling Carl and ordering his radiator and electric fan kit tomorrow. I went round and round on it, finally decided that the increased cooling and reliability was completely worth it given where I live and the desire to drive the car as much as possible. Replacing the tanks would run me a couple hundred and to me, it's worth it to go one better. Besides I don't need either cooler so the costs aren't as bad as they could be. Lots of shiny bits going on the car now!
#38
You are making a smart choice. Do it once, do it right, do it like you mean it!
#41
Try http://www.mailordercentral.com/928i...928 106 043 UN
928 International has them made custom for the 928.
#43
Captain Obvious
Super User
Super User
#44
Captain Obvious
Super User
Super User
I have the word of someone I trust that it was replaced, and 25 years of receipts and I'm sure it's in there. I'm going to stop sniping, just will say I'm not happy with the design, the mode of failure and especially the price of a new one. Definitely with Greg on that score.
#45
You could also repair the side tanks by just cutting off the Tabs and making up some stiff "c" clips. Bending the edge of the core where the end-tank seals can cause even more issues with the core and or the seal channel.
When compressing the end tank on the core I would not use clamps that put pressure on the other end-tank and its seal, as this could also damage the other tank.
Mat and I repaired my end-tank and it has lasted 2.5 summers (Two trips to SITM) and going on three winters (note: I do not drive the car in the winter).
https://rennlist.com/forums/928-foru...h-no-tabs.html
Whatever you decide to do it is great to have options
DaveK9
DaveK9
