Optimoly HT?
Received 1,542 Likes
Whoa folks! Whoaaaa....
The Optimoly HT is neither copper anti-seize nor aluminum-seize.
It is high-pressure grease. That is what you want on your clutch parts, not anti-seize.
Basic Sponsor
High (extreme) pressure grease for the clutches is 000 043 024 00 $22.86.
Optimoly HT Mounting Paste 90g 000 043 004 00 is $31.07.
Optimoly TA Mounting Paste 000 043 020 00 $36.30
^^^ Well I'll be ...
If I'd known you stock it I would have been able to make an even greater contribution to your retirement fund ... and saved myself the searching to get it here.
BTW ... my 82 complete Sachs clutch kit (PP, release, etc) included a small sachet of the EP spline lubricant.
Do y'all read that to mean that Olista should be used everywhere HT was called for, or that HT should still be used on the clutch parts that aren't enumerated (pressure plate…)?
IIRC when you order by part number you get the 3EP and if you pull back the Porsche label that's what you see.
Yes. As long as there's no confusion or errors in the WSM about where anti-seize should be used and where high-pressure grease should be used.
Do y'all read that to mean that Olista should be used everywhere HT was called for ...
