928 Forum 1978-1995
Sponsored by: 928 Specialists
Removing rust on rotors hats to prep for paint
Old 09-14-2008, 01:40 PM
F451
F451's Avatar
Default Removing rust on rotors hats to prep for paint
Hey guys,
The rotors from my S4 have developed rust on the rotors hats and around the out edge on the vane ends (they've been sitting off the car while I attend to other maint issues).
I want to remove the rust and then paint the hats and possibly the outer edge/vane ends.
Question: does anyone have any suggestions for removing the rust on the rotor hats?
I don't want to wire brush them. Some type of chemical method is preferred.
Question: Is it worth removing the rust and painting the outer edge of the rotors where the vane ends are?
Question: Are the rotor edge visisble when the wheels are on the car? If they are not visible, seems pointless to paint the rotor edge.
Any tips are greatly appreciated. Thanks!
Ed
Old 09-14-2008, 01:55 PM
F451
F451's Avatar
Originally Posted by Sterling
I used a wire brush wheel on a cordless drill took about 2 minutes per hat... don't wory about the edges.....
Why don't you want to use wire brush?
I didn't think it would be as effective as some time of chemical stripper, but hey, I have a brush wheel and cordless drill, and two minutes per hat, sounds like I can't go wrong, ha ha!
Ok, thanks, I'll give it a shot.
Old 09-14-2008, 02:39 PM
SeanR
SeanR's Avatar
Get a can of the Rustoleum stuff and it sticks to it just fine.
Old 09-14-2008, 02:48 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,234 Likes on 1,236 Posts
clean off the mating surfaces as well on the hubs and the inner hats, you can use some anti seize here so they wont rust and they will be flat
Old 09-14-2008, 03:09 PM
ROG100
Basic Sponsor
ROG100's Avatar
Use Hammerite paint - works really well
Old 09-14-2008, 03:35 PM
Chuck Schreiber
Chuck Schreiber's Avatar
Plus 1 as Roger said.
Find it at Home Depot. You can paint it on and it looks like you sprayed it. It's Rustoleum Hammered finish paint and it has a mild "texture" or hammered look to it. Jim, Roger, and I have done it. My 79 has gone 4 years with it. I brushed it on right over the rust as it says in the instructions. I also did the vents on the outside of the rotors. Use a small brush to put it on, put one more coat on per the instructions. The first time you put the brakes on, it will "wipe" a nice clean line in the hat.
Here is a some info on it http://www.epaintstore.com/xcart4/pr...6&cat=0&page=6
Buy it at Lowes or H Depot.
Easy and effective. I think Rog and Jim did theirs about a year before I did mine and theirs looks great as well.
Good luck!
Old 09-14-2008, 03:36 PM
Chuck Schreiber
Oh yeah,
IT comes in Silver, Black, and a funky bronze color. I did the 79 in black to give it a "2 piece rotor" look.
Jim and Roger did theirs in silver I believe.
Both look good!
Old 09-14-2008, 04:58 PM
cold_beer839
cold_beer839's Avatar
Or, if you are running stock S4 wheels, just leave them rusty, nobody can see them anyway.
I'm a smartass.
Paint them!!
Old 09-14-2008, 09:26 PM
F451
F451's Avatar
Ok, more good advice. I especially like the idea of being able to paint the outer edge, the vane edges, even if no one will be able to see them. I hate rust.
Thanks guys! -Ed
Old 09-14-2008, 09:43 PM
IcemanG17
IcemanG17's Avatar
https://rennlist.com/forums/showthre...painted+rotors
Been there done that....
as mentioned before you MUST remove all rust prior to paint...otherwise the paint will fall off with the rust....
two years later and my rears still look great....the fronts are not as good, showing some rust, but I think this is due to the heat generated on the track....
Old 09-14-2008, 10:51 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
clean off the rotor surface with acetone, so the pads are not cleaning off the braking surface , this could contaminate the pads and cause them to glaze as the paint will be baking into your pads
Old 09-14-2008, 11:50 PM
okbarnett
okbarnett's Avatar
Submerge in Muratic Acid. About 12 to 24 hrs. Completely strips to bare metal. Hose off and blow dry. Paint hat and back side and down into vents with heat paint. ( Not for kids. Its hot and it burns. )
Quick Reply: Removing rust on rotors hats to prep for paint
