The Official "Ask Your Novice 928 Questions Here" Thread.
#46
Okay..........I'll bite. What is the LSA (lope separation angle) on the 78 16V cams? I know that I should be able to figure it out from the valve opening and closing data in the WSM, but I'm kinda challenged in that department.
Thanks,
David
Thanks,
David
#47
The SS manifolds are lighter and flow better than stock 16V cast iron manifolds. But, cast iron manifolds with some outlet porting (51mm->55mm), flow just as well, or better, IMHO, can be upgraded on the car, and don't require a spacer. This is assuming you put 2" down pipes on either, to match.
On the flip side, removing SS manifolds and installing headers (usually) results in a reduction in horsepower.
#48
Can pre S4/post S4 car hoods be interchanged?
Seriously, the hi beams on my S4 are basically glorified parking lights that aluminate the surrounding ditches to my left and right? where's the 'bright?' Standard night driving is great, but those lower lights don't do squat.
#51
Sharkaholic
#53
#54
HTML Code:
Why does having a part start with the numbers 928 make it cost 4 times as much as the same part that starts with a 944?
Andrew, are you being serious about the brake bias valve? Maybe I am losing my sense of humour...
It sits under the Brake M/C (position changed after '83); it is not hard to take out but you have to disconnect all the brake pipes & it can be #@*"# to get the bolts exactly lined up so you can get the threads started again for each pipe.
47-17 & 47-18 in the WSM
Marton
#55
Administrator - "Tyson"
Upgrade or conversions?
#60
https://rennlist.com/forums/928-forum/307035-s4-auto-to-manual-conversion.html
https://rennlist.com/forums/928-forum/220787-calling-auto-to-manual-conversion-masters.html
Wrong direction but right idea:
https://rennlist.com/forums/928-forum/291169-latest-project-5-speed-to-automatic-conversion.html
