928 Forum 1978-1995
Sponsored by: 928 Specialists
The Official "Ask Your Novice 928 Questions Here" Thread.
Old 03-25-2009, 06:56 AM
  #226
Ben
Ben's Avatar
Originally Posted by GlenL
12mm
That's called a "triple square" hereabouts. "XZN" does sound cooler.
Thanks... ordered one and it should be here today!
Old 03-25-2009, 07:30 AM
  #227
ptuomov
ptuomov's Avatar
Originally Posted by Rob Edwards
Tuomo-They should come right off the nose of the cam easily. Are both of yours stuck in place? Maybe a little overnight Kroil soak and a gentle persuasion with a 3-ear gear puller? (Cams are brittle, take it easy...) Is the woodruff key on the camshaft skewed somehow so the hub can't slide forward? Maybe you could tap the key back/down a bit?
It came off just fine with a three-point gear puller, but it was in there real tight. I was surprised to see the woodruff key not being crescent shaped, live and learn. The first set of camshafts is now liberated. Thanks for the pointers.
Here's a question to people living near boston. Is there a shop in or near boston where you can buy quality tools? I've got some "OEM" bits etc. and the usual Autozone tools, but they are not up to the task. I am looking for things such as a valve spring compressor that works well on the 928 head, XZN bits that don't strip themselves or the bolt, etc.
Old 03-26-2009, 12:40 PM
  #228
ptuomov
ptuomov's Avatar
Here's another stupid novice question. What are the exhaust and intake valve angles in S4 head? Not the valve seat cut angles, but the valve angles. Thank you in advance.
Old 03-27-2009, 11:20 AM
  #229
sidehatch
sidehatch's Avatar
Hello can anyone post a link for a how to on battery drains,i know i have other mechanical issues to deal with,but mabe this one i can try to fix i have a dmm,also the battery is new, and i cleaned the posts on the negative were it ties down.Also the connections in the front.
Quick Reply: The Official "Ask Your Novice 928 Questions Here" Thread.
