928 Forum 1978-1995
Sponsored by: 928 Specialists
Need tech. advise!!
Old 06-26-2001, 03:18 AM
Jason E
3rd Gear
Jason E's Avatar
Unhappy Need tech. advise!!
This is my problem, the pivot ball for the clutch is broken. What is the best/simplest way to remove the upper clutch housing? any help would be great. 80 5spd euro
Old 06-27-2001, 02:00 AM
Jim V
Jim V's Avatar
Post
When I couldn't drive the pins out to drop
the clutch on my '83 Euro I was able to un-
bolt the trans. and push it back with the TT
attached.
This should also give enough clearance to drop the upper bell.I assume you've got the
clutch out already?
Quick Reply: Need tech. advise!!
