928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine Shutting Off/Not Turning Over
Old 06-21-2001, 06:36 PM
Alwin928
Alwin928's Avatar
Red face Engine Shutting Off/Not Turning Over
I am having a problem with the engine in my '85 928 shutting off or not starting. The fuel pump relay, fuel pump and filter have been replaced. It has also been serviced which included plugs and rotor. It is a weekend car so it is not started daily. When I do attempt to start it, some days it will not start or it will start and die. Other days, it starts right up and runs fine. Ignition coil? Any ideas/suggestions will be grateful!
[ 06-21-2001: Message edited by: Alwin928 ]
Old 06-21-2001, 07:07 PM
Tabor
Tabor's Avatar
Post
On my 944, it was not the Fuel pump relay that was bad, but the wiring inbetween it and the fuel pump.
On the 944 it is easy to monitor fuel pressure. Is this true on the 928? You need to determine if you have adequite fuel pressure.
Old 06-21-2001, 11:13 PM
jim morehouse
jim morehouse's Avatar
Post
928 Specialists (and maybe 928 Intl) sell a guage that mounts on the forward end of the fuel rail..I think the cost is around $50 total.
Jim
Old 06-22-2001, 12:46 AM
fast928
fast928's Avatar
Post
I just had a similar problem on my '85. Check your coil wires. One of my coil wires looked like it was cooked.
I replaced that coil wire and the coil for that side just to be safe. It's been working great ever since!!
Good Luck!!
Old 06-22-2001, 01:28 PM
Moss928
Moss928's Avatar
Post
Your problem sounds a little like mine (hard starts in the morning 6/22/01 Moss928).
What do you mean by not turning over? Do you mean that it turns over, but does not start?
Quick Reply: Engine Shutting Off/Not Turning Over
