928 Forum 1978-1995
Sponsored by: 928 Specialists
Another way to save time on the clutch Hydraulics
Old 10-25-2012, 11:24 PM
  #31
the flyin' scotsman
the flyin' scotsman's Avatar
Originally Posted by kawi825
The other question, i was thinking of once this all together and installed, of trying to fill the system from the slave bleeder using a boat style lower unit hand pump. this way it fills from the bottom, and pushes the fluid and air up through the reservoir. This make sense, or am i missing something??
this method can work. in fact theres a video out there showing BWM service folks demonstrating.
I found the method inadequate when I bled the GTS clutch system and ended up reverse bleeding using the slave pushrod, pumping it ~20 times.....bon chance.
Old 10-25-2012, 11:52 PM
  #32
Donald
Donald's Avatar
Stan, Dave et al:
got it all out today. I had to remove the nuts from the booster completely, push it outboard and really manhandle the MC before it came loose. The leak was in the bottom flex line, but I will rebuild the MC now.
FWIW, I tried to pressurize from below (in the parking lot of 3rd Coast last year- what are the odds of someone having a spare blue hose & slave in the car- Hermann does!!) when I lost my slave cylinder; it did not work. Pumping the slave rod did.
Old 10-26-2012, 12:05 AM
  #33
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,243 Likes on 1,241 Posts
when you go to refit the MC get a long bolt,
and thread it into the MC once its close to being in its proper position.
Then you can pull the MC into position and install the other bolt,
also make sure the blue hose is routed so its a continual rise to the reservoir, turn the inlet fitting of the MC to make this happen.
on your new flex hose put a piece of heat resistant shielding,
found at autozone in the performance section
Old 10-26-2012, 08:43 AM
  #34
17prospective buyer
17prospective buyer's Avatar
When you bleed the hydraulic system, do you bottom out the slave piston (clutch engaged position) and keep it bottomed out with something heavy (like bolting it to a wall lol) while bleeding the system? Mitchell doesn't say anything about having to do that.
Old 10-27-2012, 02:59 PM
  #35
kawi825
kawi825's Avatar
after an hour of swearing and wiggling, i finally got my MC out of the 78 this morning without losening the booster, not sure how in the world i'll get the new one in at this point.
Dave, (or anyone..) how in the world can you get any leverage/movement on the wrench on the flex/hardline bracket on the motor??? i can barely get a wrench on there, but no way in h*ll is there any room to break it free, i'm completely stuck on the last bolt in the system, and it's killing me... TIA.
Old 10-27-2012, 03:21 PM
  #36
Mrmerlin
Team Owner
Mrmerlin's Avatar
kawiMATT please post a picture
Old 10-27-2012, 03:45 PM
  #37
kawi825
kawi825's Avatar
Not a good pic at all.. but this is driver side, behind motor, under airbox, the loop from the engine hoist pick point is visible. the bolt is a few inches below it. i can see the bolt from underneath, but can't access it from there either. i really don't know how any of you guys have gotten this thing off. I can BARELY slide my hand behind the motor with a 13mm wrench in my fingertips, but not a chance of actually doing anyhting with it..
i have the master and slave off, and this damned thing is the only thing keeping me from driving this car a couple more times before the white crap starts to fall.. Thank you much for the reply
Old 10-27-2012, 03:49 PM
  #38
kawi825
kawi825's Avatar
i did notice Sharkskin's pic had the airbox off, but i don't know if this would make much difference. BTW, how does the airbox come off on the OB's other than the 2 bolts on the ends of it? i took mine out awhile back, and something is still holding it on tightly
Old 10-27-2012, 08:24 PM
  #39
Mrmerlin
Team Owner
Mrmerlin's Avatar
airbox removal would be a asset,
to remove it look on the top of the spider body their is a 13mm bolt with a locknut,
remove this bolt and the aircleaner lower section will come free .
The bolt is a long part about 7 inches long, it presses the front portion of the aircleaner body onto the intake opening.
with the aircleaner removed you should be able to get to the bolt
Old 10-27-2012, 08:36 PM
  #40
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
Don't forget to remove the air hose to the air pump on the bottom passenger side of the lower air box
Old 10-28-2012, 05:05 AM
  #41
Fogey1
Fogey1's Avatar
Originally Posted by AirtekHVAC
WOW!! Did anyone notice Dave made a post? (Sharkskin).(and on an old thread resurrection no less)..have not seen any from him since I have been on.....He is like my hero (Ok, one of many here)..lol...I found his pages before I bought my 78, and his write ups brought me here!!!
+928. Dave's one of the treasures of this community.
Old 10-28-2012, 10:07 AM
  #42
LT Texan
LT Texan's Avatar
after an hour of swearing and wiggling, i finally got my MC out of the 78 this morning....
Not bad.
Putting it back in is lots of fun too.
Old 10-28-2012, 12:18 PM
  #43
kawi825
kawi825's Avatar
Thanks a bunch guys. Airbox did the trick, shame on me for not trying it sooner. I think my patience wore too thin, should've taken a break and went back out. Now the only thing holding me back is the 45 fitting for the blue hose. I thought I read somewhere these came with the new masters but I guess I was wrong. Have a note to Roger. Hopefully I can get one quick. Thanks again.
Old 10-28-2012, 01:16 PM
  #44
Mrmerlin
Team Owner
Mrmerlin's Avatar
what is a 45 fitting for the blue hose?
Old 10-28-2012, 02:21 PM
  #45
kawi825
kawi825's Avatar
That little plastic 45 deg nipple that fits onto the mc. Mine is in rough shape and oblonged. Don't want a .30 part to defeat me..
Quick Reply: Another way to save time on the clutch Hydraulics
