928 Forum 1978-1995
Sponsored by: 928 Specialists
CIS K-JET Cold Start Issue
Old 06-12-2007, 12:23 PM
  #61
checkmate1996
checkmate1996's Avatar
No. I am not running any cats. headers, straight pipes....only.
Old 06-12-2007, 05:49 PM
  #62
hupp
hupp's Avatar
My shark smelled rich with no cat installed. With the cat, no rich smell.
Old 06-12-2007, 07:17 PM
  #63
telidor99
telidor99's Avatar
I had a similar Problem with my Euro 928 (1981). Took a number of trys to get it to start. I had to give it a small amount of gas for a minute or so..then it was fine. Turned out being the Warm-up Reg.
Had mine refurbed.
Old 06-15-2007, 08:13 PM
  #64
checkmate1996
Default Update 6/14
Ok, I just got a brand NEW switch out of the box PLUS two other used switches.
Results:
BRAND NEW SWITCH:
- W & G Connected together- (WSM=20-40 OHMS (Mine = 35.6)) (In-Spec)
- W to Ground - (WSM=0 OHMS (Mine = 0.9))
- G to Ground - (WSM=0 OHMS (Mine = 36.0))
Switch#2:
- W & G Connected together- (WSM=20-40 OHMS (Mine = 39.3)) (In-Spec)
- W to Ground - (WSM=0 OHMS (Mine = 2.8)) (Out of Spec)
- G to Ground - (WSM=0 OHMS (Mine = 37.5)) (Out of Spec)
Switch#3
- W & G Connected together- (WSM=20-40 OHMS (Mine = 38.4)) (In-Spec)
- W to Ground - (WSM=0 OHMS (Mine = 7.9)) (Out of Spec)
- G to Ground - (WSM=0 OHMS (Mine = 38.6)) (Out of Spec)
So, is the WSM on CRACK? 3 switches can't lie.
Switch#2 seems reasonably in check. I hate to spend $80 if I don't have too...now I"m really confused...or is there that much difference between 0.9 and 2.8?
Old 06-15-2007, 08:17 PM
  #65
checkmate1996
Had mine refurbed.
I think you mean AIR!!
Old 06-15-2007, 10:28 PM
  #66
Dennis Wilson
Dennis Wilson's Avatar
If your meter is reading correct (appears to be since the connector to connector is in spec) the new one is also bad. It won't be the first time a new part was defective.
Dennis
Old 06-16-2007, 02:12 AM
  #67
Optimator
Optimator's Avatar
In this case, I think so! DON'T RTFM?? Look at the schematic representation of the switch as shown in both the WSM and the wiring diagram. When the switch is cold, "W" is grounded, which means that "G-to-W" and G-to-ground" are essentially the same thing. Therefore, you would expect the resistance readings to be about the same. The 0 ohm for G-to-ground spec in the service manual must be a mistake. Am I wrong?
I'm not sure how low the resistance needs to be for the CSV to open reliably. As shown in my last post, my switch measured nearly identical to your new switch. My switch works - I watched it open and close my CSV. If you are curious about any of your new or used switches, you can perform the same test, which should be pretty conclusive....
Old 06-19-2007, 01:10 AM
  #68
checkmate1996
Default Update 061907 - Stick a fork in it!
OK. I think we have come to the end of the road with this saga.
I put the new thermotine switch in, filled all the fluids back up and VOILA, it turned over in 2 seconds after sitting for 2.5 weeks!!!! I tested it again today after sitting for two days, and again, it turned over in less than 2 seconds.
I think I'm going to call this mystery solved.
What did I learn: 36,1,36 are good measurements to go by! Don't RTFM on this one!!
I also embedded an updated shot of my engine put back together with upgraded silicone hoses and refinished *EDIT* stiffening brace. Thanks for all of the help!
Cagliere (02-21-2021)
Old 06-19-2007, 09:00 AM
  #69
hupp
hupp's Avatar
Checkmate,
Where did you buy the hoses?
Old 06-19-2007, 09:24 AM
  #70
Dennis Wilson
It appears the design of the switch has been modified to ground internally rather than relying on a wire connection. This is alright as long as nothing else is being powered on the negative side of the switch. Did we miss an update to the WSM?
Dennis
Old 06-19-2007, 02:27 PM
  #71
checkmate1996
Originally Posted by hupp
Checkmate,
Hupp,
Boostcontroller.com. Good prices and great service. Everything is in METRIC!!
The hoses fit AWESOME and take considerable force to pull off.
Good luck!
Old 06-20-2007, 01:17 AM
  #72
jpitman2
jpitman2's Avatar
Hupp, thats not the 'anti-sway' bar as I know it. My anti-sway bar is connected to the lower suspension arm and the body underneath....A stiffening brace is more what it is.
jp 83 Euro S AT 50k
Old 06-20-2007, 09:43 AM
  #73
hupp
hupp's Avatar
jp 83 Euro S AT 50k
jpitman,
I'm with you on that one, but take a look at checkmate's comment with the engine pic......
He know's what he's talking about though...
Old 06-20-2007, 10:26 AM
  #74
checkmate1996
I'm learning everyday...if stiffening brace is the right terminology...then I want to use it!
Old 06-20-2007, 11:00 AM
  #75
Dennis Wilson
It is called a shock brace and it is a MUST. There have been instances when raising the front end of the car without the brace has resulted in a broken windshield. Also, with that much movement, your alignment would be adversely affected.
Dennis
Quick Reply: CIS K-JET Cold Start Issue
