928 Forum 1978-1995
Sponsored by: 928 Specialists
How do you remove/disassemble the hatch upper latch? Now - Hatch rattle fix.
Old 08-11-2010, 05:14 PM
  #31
Th Dude
Th Dude's Avatar
Thumbs up
Thank you, Bill. Yet again, you've saved me time and money. The details and photos are great. I never would have gotten that spring back in correctly without your little screwdriver-big screwdriver tip. You're an amazing asset to this community.
Be well,
Derek
Old 08-11-2010, 07:32 PM
  #32
vtc4198
vtc4198's Avatar
This is so funny how this thread got bumped today, the day I noticed a little rattle in the rear. LOL
I pulled out the rubber stoppers on ea side a bit. Nearly quiet now, but this fix will need to be done in the near future.
Great thread Bill. Thanks for the effort, documentation and pics
A great group of guys here
Old 08-11-2010, 07:46 PM
  #33
Bill Ball
Under the Lift
Bill Ball's Avatar
Yeah, I don't believe the bumpers really should be used this way, but go ahead if it helps until you can replace the tongue. They should be more or less to adjust height and to prevent the lid from making contact with the body. Some people screw them way out so the hatch will "pop" open, when if working right it should open with no pop sound as the lower latch spring shoves the tongue out. Mine has been working great since the above fix, but the upper latch did have a tiny crack, which is now almost all the way across. New part is around $400; used unavailable.
Old 08-12-2010, 01:38 AM
  #34
Nicole
Cottage Industry Sponsor
Nicole's Avatar
After I replaced the white lock latch, my hatch still rattled on bumpy roads.
Then I got the lower hatch receiver inserts made, and even though the old one still looked good, I decided to try it. Since then the hatch closes tighter, and no longer rattles.
I can't say I understand why this is, but that's what I experienced.
Old 03-19-2012, 01:30 PM
  #35
Randy V
Randy V's Avatar
My hatch sits high - so much so that the rear wiper does not engage with the motor cam.
I can push it down with my hand.
Is this the fix I need?
The side rubber guides are not holding it up, nor are the corner bumpers.
Old 03-19-2012, 02:35 PM
  #36
Ron_H
928 Barrister
Ron_H's Avatar
I have a PERFECT condition upper hatch latch sitting on my desk, alongside a caliper I will use to measure it. If I would discipline myself enough to draw this latch on acad like I intended to do several months ago, and take the acad drawing to my Porsche machinist friend in Sunnyvale who also happens to have a CNC machine, we could all rest easier. He will knock out a replacement latch housing in steel that WILL NOT CRACK. He will do it if we can reasonably guarantee him a market of sufficient size to make the development of this latch a reality because we are operating on faith that enough 928ers will purchase one to make it worth his effort to create them. So far, my hesitation has been based on both the current in-the-toilet economy and concern that we won't have sufficient market to make it worth while to produce the latch housing in meaningful quantity. Translation: It IS available if I would just do my part. I will as soon as I have some food in the cupboard to take the time to produce the drawings.
Old 03-19-2012, 02:36 PM
  #37
fbarnhill
fbarnhill's Avatar
Randy, If the plastic insert in the bottom receiver is not broken, then this probably will help your issue. On mine, I know I need it because my white nylon bumper is worn flat.
Old 03-19-2012, 02:38 PM
  #38
fbarnhill
fbarnhill's Avatar
Well, Ron, mine is also cracked. I am going to try to continue to use it but if your guy can do it at the right price, I will be interested.
Old 03-19-2012, 02:57 PM
  #39
Bill Ball
Under the Lift
Bill Ball's Avatar
Worth trying, but in Nicole's case we found a spacer plate under the top of the lower receiver. Seemed like factory piece used to adjust the latch. We took that out and with the tongue renewed, the hatch finally sat down at the proper height. If it is not engaging the wiper mechanism, you know it's way too high.
Old 03-19-2012, 04:08 PM
  #40
Randy V
Randy V's Avatar
I don't think mine is cracked.
Mine also has that shim under the lower receiver. I'll try taking it out, but I don't think it will make enough difference to bring the hatch down flush.
Old 03-19-2012, 04:52 PM
  #41
Bill Ball
Under the Lift
Bill Ball's Avatar
Well, do that first. Make sure the bumpers are turned in and see how it works then. The tongue wears in its pivot pin hole and drops down. Replacing that is the next step. It worked for me.
Old 06-15-2012, 01:08 AM
  #42
nexty226
nexty226's Avatar
Post
Mine just broke. The upper housing was craked and it just pop. Now looking for one and mine has alarm ,so I now it will be a litter bit spencive. No luck yet...
Old 06-15-2012, 01:33 AM
  #43
Brett Jenkins
Brett Jenkins's Avatar
I might be able to help you out with that. I will look tomorrow or saturday. What part/parts do you need exactly.
Old 06-15-2012, 01:35 AM
  #44
Ron_H
928 Barrister
Ron_H's Avatar
How many people are interested in my friend producing these latches (upper) in steel on a CNC machine? If you don't plan on keeping your shark for more than a few months or couple of years, it is unlikely that you will want to order on of these. I want one, but am not currently driving my 928, and when I am, I am VERY careful not to stress the latch by slamming it. And mine already has a hairline crack in it. I was lucky enough to find a used good condition one from a P car wrecking yard sometime back. And I still have the perfect condition one on my desk.
So how many can we expect to buy the steel one if we produce it ?? I can draw it in a weekend day or less.
Old 06-15-2012, 01:51 AM
  #45
nexty226
nexty226's Avatar
Post
Great thank ok, on the second page of this thread mj1pate posted two pictures ,the pice I need is the one he is holding. That is the upper housing, the little white arm is okay. On that pic you'll see that it has a gray line, there is where mine broke.
Quick Reply: How do you remove/disassemble the hatch upper latch? Now - Hatch rattle fix.
