928 Forum 1978-1995
Sponsored by: 928 Specialists
Ignition switch wiring, what color goes to what?
Old 02-11-2007, 02:09 AM
Benton
Benton's Avatar
Default Ignition switch wiring, what color goes to what?
Hey guys, after all of this time, I'm finally getting on the home stretch of my race car. I need some help, though. I thought I taught myself how to read wiring diagrams, but these are pretty confusing. On my 86, they ignition switch is broken and I have a universal starter button and ignition switch left over from a previous car that I am going to install. All I really need to know is what each of the wires on the back of the ignition switch correspond to, but I am having a tough time understanding the wiring diagram for this car. It is an '86 5 speed. If anyone can tell me what color goes to what, and when it is switched, I would greatly appreciate it.
Old 02-11-2007, 09:18 PM
Alan
Electron Wrangler
Alan's Avatar
Reds are battery in (30)
Blacks are Ignition out (15) (on in position 2 & 3 only)
Yellow is Starter(relay)(50) (on in positions 3 only)
Black/Yellows are Accessories(X) (on in positions 1 & 2 only)
Red/Black(thick) is Radio Supply (on in Positions 1,2,3)
Red/Black(thin) is power in (30) to key-in switch
Grey is Off (on in Position 0 - key in or out)
Black/Red is key-in switch output(*) (on when key is in)
Switch Position
* Key Out
0 Inserted only
1 Accesssory Only
2 Ignition
3 Starter
Alan
Old 02-11-2007, 09:37 PM
Benton
Benton's Avatar
Alan,
Thank you so much for the help. I noticed you are some type of wiring genius while searching for any past posts on this subject; I was hoping you could chime in. Again, thanks for the help.
Old 02-12-2007, 03:09 PM
Benton
Benton's Avatar
Alan,
What exactly do these three wires send power to? I'm a bit confused as to what the function is.
Old 02-12-2007, 03:32 PM
Alan
Electron Wrangler
Alan's Avatar
The Grey (off switch) is used to power the parking lights controlled by the turn signals.
The Black/Red is used for several things - it initiates a timer used for the seatbelt warning and is used to sound the chime if you open the door with the keys left in the ignition.
The Red/Black is just the power supply from the battery for this special switch.
Alan
68427vette (03-04-2024)
Old 06-30-2007, 09:51 AM
stigity
stigity's Avatar
Default photo
My harness pulled out and left me a mess, do you have a photo of the harness showing what wire goes where?
84 928s
Old 06-30-2007, 03:13 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
84 928s
Here's a picture that might help. Sorry, couldn't resist posting one of my favorite 928 wiring pics.
Old 06-30-2007, 04:35 PM
Alan
Electron Wrangler
Alan's Avatar
Bill - did you also notice that the top of the drivers door has accidentally been sawn off too...? seems appropriate actually...
Alan
Old 06-30-2007, 08:26 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by Sterling
Isn't that one of Dan the Pod Guy's convertables?
Yep. Scariest 928 photo ever, at least for electrophobes like me.
Somehow, Dan got it back together.
Old 03-30-2015, 07:36 PM
MarkRobinson
MarkRobinson's Avatar
I'm doing this now on my race car, so from Alan's post attached, I'll connect my switches as-follows to a normal two pole master switch:
Red & Red (30) to lower leg of master switch
Black and black (15) to upper leg of master switch
Black and yellow (x) to upper leg of master switch
Starter button will be wired as follows:
New wire from the upper leg of master switch
Connect to yellow wire that feeds the starter relay
None of the other switch wires were connected on my running racer so I'm ignoring them/removing them.
Sound right? What threw me off is that there's no grounds in the switch, just connecting constant powers to make switched powers plus the starter.
Mark
Switch Position
* Key Out
0 Inserted only
1 Accesssory Only
2 Ignition
3 Starter
Alan
Old 03-31-2015, 12:19 AM
Alan
Electron Wrangler
Alan's Avatar
Sounds fine for your usage
Alan
Old 06-19-2017, 09:16 AM
AO
Supercharged
AO's Avatar
Wanted to bump this and say thanks. My Coke car was having some issues where the ignition would cut out occasionally in mid-corner. There were also a couple times when I would turn the key and nothing would happen. No relay click, no lights, nothing. So I'm 99% sure it was the ignition switch.
I added this switch setup for $20. Works great. And as you can see it's for "Racing use only!" LOL!
Old 06-21-2017, 10:30 AM
Chris Lockhart
Chris Lockhart's Avatar
That the one from Superbright LED's or Fleabay of whatever? I see them around a lot, and wondered as to their quality. S-I-L wants one for his car that has a seriously messed up ignition switch.
Quick Reply: Ignition switch wiring, what color goes to what?
