928 Forum 1978-1995
Sponsored by: 928 Specialists
View Poll Results: Interested?
32V cam timing tool
79.31%
16V/32V conversion
20.69%
Voters: 29. You may not vote on this poll
32V Cam Timing Tool & 16V/32V Conv 'Group Buy' #2
Old 02-09-2005, 07:27 PM
  #61
PorKen
Inventor
PorKen's Avatar
Default Update
In post #52, I was incorrect in saying that the GT cams measured (2) degrees advance. After adjusting and rechecking both cams with the dial indicator, the actual measurement is (1) degree advance for both sides.
I picked up the new batch today. I need to do some quality control checks and then they'll be ready to ship.
I have enough pictures for the manual, and I'm working on the copy.
Old 02-10-2005, 11:35 PM
  #62
PorKen
Inventor
PorKen's Avatar
Default The last straw...
The pointers were bent incorrectly. Shop says they cannot guarantee bending to tolerance. (The first two were a fluke that they turned out right.)
Perhaps a two piece design could work, but I'm done.
Thanks for all your support, and suggestions.
Refunds going out tonight! (If you have been shipped a pointer, you must return it to me for refund.)
The 16V kits are fine, those will ship shortly.
Old 02-10-2005, 11:44 PM
  #63
Jim_H
Jim_H's Avatar
Sorry to hear that Ken. You put a lot of time and effort into this, including many trips cross town during rush hour
I have no doubt your next project will turn out much different.
Old 02-11-2005, 12:01 AM
  #64
Jim R.
Jim R.'s Avatar
Ken,
Sorry about the production problems. It was a great idea, and you put a hell of a lot of time into it without even owning a 32v 928.
If you could be convinced to lend out the working set, let me know. I really don't want to pull my cam covers yet(powdercoating, then pull the intake again to PC match) to align the cams.
Hey, maybe you could try your hand at an x-pipe instead!
Jim R.
Old 02-11-2005, 02:57 AM
  #65
PorKen
Inventor
PorKen's Avatar
Thanks Jim(s),
I made the mistake of trying to design something that I do not have ready access to. With the 16V kit, I could easily stare, measure, stare, measure, and test on my own car.
The tight tolerances are also a problem for ready design of such a tool. I would not want to put something out there that gives inconsistent results.
I figure the working two cost about $600 each. I hope Jim_H will give me his back, so I can resell them both as 'limited editions'.
Old 02-11-2005, 01:08 PM
  #66
SharkSkin
SharkSkin's Avatar
Ken, I ran this by my brother (http://www.prototype-design.com/) and he had the following to say... may/may not be of use to you, but what the hey:
Dave,
I can suggest Quality Metal Fabrication in Auburn, 530-887-7388.
I'm reasonably certain they can hold his tolerances, and quite certain that if they say they can, they can. If they don't think they can, they will say so.
I have little chance of being able to mill/drill that part in the flat and bending it up accurately enough for everything to line up and work. I'd have to machine separate parts and assemble.
Hmm, one suggestion you might pass along however, consider moving the timing index holes to the plate that bolts to the pulley and having a single point pointer at the timing mark. If the circular ring were larger in diameter, coming out near the pulley ID, should be able to keep holes far enough apart. I'd suggest opposing holes 180 degrees apart for each adjustment position. The adjustable indicator part would need a pair of press fit pins to match the holes in the circular plate.
A couple Pem studs coming up out of the circular plate and mating with adjustment slots would secure the indicating arm to the circular plate.
This would move the precision away from a bending operation.
Would be happy to try to communicate this idea a bit further with Ken.
Jon
His email address is on the page linked above. He's done quite a bit of very creative problem-solving; far more than he's had time to post on his site. might be worth shooting him a note or call.
Old 02-11-2005, 01:26 PM
  #67
sharkmeister85
sharkmeister85's Avatar
Ken,
Please don't give up on this project yet! Contact Dave A.'s brother as he suggests. I think this thing is too important. Step back and take a break if you must, but don't let it die.
Glenn
Old 02-11-2005, 02:56 PM
  #68
heinrich
928 Collector
heinrich's Avatar
Ken, how about simpler? We know the cam can move only so far between the slot ends on the 32V. Can we assume properly-adjusted cams and just mark the cam gear so that it actually reads how much advance/retard? I see no reason actually to go beyond that.
Old 03-03-2005, 11:32 PM
  #69
PorKen
Inventor
PorKen's Avatar
Lightbulb Voila!
After some time away from this project, I came up with a simple fix. A laser width line, cut through 1/4 the width of the arm, forces a bend at the critical 90 degree section. (I also added a flat on the arm end for easier setup by the shop, and they spend more time on the setup.)
The cut does not affect the strength, it is still difficult to bend.
I'll post a new thread for this final version, once the manual is finished, as this thread is too long now.
Old 03-04-2005, 12:04 AM
  #70
BC
BC's Avatar
Help me here Ken.
I have the 16V ones with the white painted pointer thingy.
I have the 32V ones (I think) with the bends and little rippes at the outer edge and some nice stainless hardware.
I see a pic below that looks really cool - would these work for both cars (32V and 16V) or should I be sending one of my other sets back to you?
I took my fenders off - great place for some fixed light brackets
Old 03-04-2005, 12:29 AM
  #71
PorKen
Inventor
PorKen's Avatar
Originally Posted by BrendanC
1. I have the 16V ones with the white painted pointer thingy.
2. I have the 32V ones (I think) with the bends and little rippes at the outer edge and some nice stainless hardware.
3. I see a pic below that looks really cool - would these work for both cars (32V and 16V) or should I be sending one of my other sets back to you?
4. I took my fenders off - great place for some fixed light brackets
1. Those are collectable hand made pointers! They work, but the stainless ones are better.
2. Those are the real 16V setup pointers. (see the pic in the beginning of this thread)
3. They only work with 32V engines. There are two separate kits, 16V conversions, and 32V cam timing tools.
4. I've got two projects in the works using my new sheet metal skilz. Fixed seat brackets (should lower seat by 3/4"), and fixed headlight brackets. The seat brackets, and the low beam bracket are done, I still have to design the high beam bracket (which replaces the US driving light), then send them all off to the laser/bending shop for another round of prototypes!
Old 03-04-2005, 08:47 AM
  #72
Jim R.
Jim R.'s Avatar
Ken,
Sign me up again for a set of the new, improved 32 valve pointers. Great effort to get back in and get these made!
Jim R.
Old 04-18-2006, 10:10 PM
  #73
Drifter
Drifter's Avatar
Help me here Ken.
AWSOME workmenship Ken.. Put me down for one 32 V version. PM me with payment info.
Quick Reply: 32V Cam Timing Tool & 16V/32V Conv 'Group Buy' #2
