928 Forum 1978-1995
Sponsored by: 928 Specialists
View Poll Results: Interested?
32V cam timing tool
79.31%
16V/32V conversion
20.69%
Voters: 29. You may not vote on this poll
32V Cam Timing Tool & 16V/32V Conv 'Group Buy' #2
Old 02-02-2005, 07:45 AM
  #31
SharkSkin
SharkSkin's Avatar
Slippery slope, eh Ken?
Old 02-02-2005, 10:27 AM
  #32
Jim_H
Jim_H's Avatar
Bingo! I could see the wheels were turning. Couldn't you get by with just one tool for both sides in that case Ken? With the pin I take you will keep the 1 degree incements also? Your pics are on the way.
Originally Posted by PorKen
A long needle, such as a hat pin, will go through the two sets of holes, and into the recessed mark on the 32V engines.
Old 02-02-2005, 02:18 PM
  #33
PorKen
Inventor
PorKen's Avatar
Thanks Jim for sending the pics.
The right cam gear is recessed into the housing, whereas the left is away. I thought maybe I'd have to have two separate pointers, but the 'hat pin holder' seems like it will solve the problem. Hopefully, it won't create new ones.
"No...not going to Hooters...I'm going to go to the craft/fabric store, 'honey bunny'..."
Old 02-02-2005, 05:53 PM
  #34
Earl Gillstrom
Earl Gillstrom's Avatar
Ken,
Looks good and I hate to suggest a change now, but, it seems that I do many checks and rotations until I get it "right on". Maybe make the mounting holes large enough to slip over the heads of the bolts for a check without removing the bolts? And then easily remove the tool for more checks or adjustment? I don't think that this would affect accuracy.
Old 02-02-2005, 06:17 PM
  #35
PorKen
Inventor
PorKen's Avatar
Earl,
I could resize the bolt holes so that they just fit over the allen head bolts.
The ring would have to be slightly larger, and I would need to include some fender washers to go under the bolts, too.
Old 02-02-2005, 06:37 PM
  #36
SharkSkin
SharkSkin's Avatar
Ken, the allen bolts may vary, and some folks may have hex head bolts. Maybe it would make more sense to have something like what you show in post #32, where you sight between two holes or use a pin or other type of pointer... but offset it further so that it clears the belt when turning. Maybe this way you can make one part for all applications... Also I like the beefier arm in that pic.
Old 02-02-2005, 07:48 PM
  #37
PorKen
Inventor
PorKen's Avatar
Dave,
Very good points.
I'm sizing the holes to the SS allen head bolts I included with the 32V sets. I measured the remaining ones in the box, and they all were the same size. The 16V pointers are set in stone, I'm not going to revisit them. The left side indicator on the housing is too low for an 'over the top' pointer.
If someone looses a bolt, or the special needles, I can make a tidy profit off of replacement parts. Say, $5 each? Wait... Porsche? Oh, I meant $10!
As it turns out, I put the 90 degree bends too close to the needle holes, and they bent at the holes with the die they were using, this afternoon. Which means I can incorporate the bolt head mod in the rererevision I'll send them tonight.
Anything else I should include?
Old 02-02-2005, 09:58 PM
  #38
PorKen
Inventor
PorKen's Avatar
Here's what I'm running with, put 'er on a bit of a diet too.
Old 02-02-2005, 10:55 PM
  #39
H2
H2's Avatar
Porken,
Thanks for doing this research for an important tool. You'll be doing the 928 community a big favor...and I hope you don't lose your shirt in the process. It's interesting to get on-the-fly feedback as the design perfects.
Harvey
Old 02-03-2005, 04:39 PM
  #40
PorKen
Inventor
PorKen's Avatar
Default The "Pin-Pointer"...
Looks like it might work!
I'll hopefully be testing the fit this afternoon. Saturday, I may be able to compare it to the dial indicator measurement.
Old 02-03-2005, 04:43 PM
  #41
heinrich
928 Collector
heinrich's Avatar
Ken, looks like an instrument of torture. How much etra will it be for me to purchase the updated version?
Old 02-03-2005, 10:00 PM
  #42
PorKen
Inventor
PorKen's Avatar
Default I think it's a keeper!
Jim_H's GT left, as found, 1 degree advance:
Jim_H's GT right, as found, 2 degree advance:
Crank at #1 O|T.
Still have to see how they measure up to the WSM, but I reckon it's close.
heinrich,
"For external use only."
It will only cost you, and the other 'first batchers', $3.85 for Priority Mail, to send the 16V pointers back to me so I don't have to do another run of those.
Old 02-04-2005, 02:19 AM
  #43
heinrich
928 Collector
heinrich's Avatar
Cool Ken, I'll send!!
Old 02-04-2005, 04:22 AM
  #44
T_MaX
T_MaX's Avatar
Ken your getting warmer!
Old 02-04-2005, 04:41 AM
  #45
T_MaX
T_MaX's Avatar
Something like this maybe?
Quick Reply: 32V Cam Timing Tool & 16V/32V Conv 'Group Buy' #2
