Porsche fuel line size *Solved* - with some info/?
For those of you who used the AN10 adapter to barb fitting, what fuel line did you use to connect to the tank fitting? AN10 requires a hose with 5/8" inner diameter. The stock fuel hose is 14mm diameter on the strainer end and 12mm diameter on the pump end. There is no way 12mm hose is going on the AN10 barb. Did you use a reducer of some kind?
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
