928 Forum 1978-1995
Sponsored by: 928 Specialists
S4 AUTO TO MANUAL CONVERSION
Old 10-05-2004, 10:58 AM
TRUESCOTSMAN
TRUESCOTSMAN's Avatar
Default S4 AUTO TO MANUAL CONVERSION
HI ALL. i AM PLANNING TO CONVERT MY 91 S4 AUTO, TO A FIVE SPEED MANUAL......ANYBODY TRIED THIS BEFORE? i NEED A LIST OF PARTS, AND PITFALLS INVOLVED IN SUCH A CHANGE.. ANY HELP WOULD BE APPRECIATED .............JIM
Old 10-05-2004, 11:05 AM
Abby Normal
In Your Face, Ace
Abby Normal's Avatar
Sell your auto and buy a 5 speed...jmo
Old 10-05-2004, 11:21 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,229 Likes on 1,257 Posts
Raising the number of manual's is a good thing.
Old 10-05-2004, 11:25 AM
TRUESCOTSMAN
REASON FOR THE CHANGE IS THAT THERE IS A PROBLEM WITH THE AUTOBOX, BUT THE REST OF THE CAR IS PERFECT AND IT IS ALREDY" MINE".............JIM
Old 10-05-2004, 11:50 AM
ROG100
Basic Sponsor
ROG100's Avatar
Jim,
Check out Sterling's site - he did it.
www.928sg.com
Best,
PS: Will be in Scotland next week near Dundee
Old 10-05-2004, 11:54 AM
hacker-pschorr
BTW TrueScotsMan, stop yelling, it's not polite.
Old 10-05-2004, 12:00 PM
MikeN
MikeN's Avatar
It can be done, but it requires a lot of work. As Abby suggested it would probably be better to find an original 5sp. and work with that.
Old 10-05-2004, 12:09 PM
Rob Roy
On the Bandwagon
Rob Roy's Avatar
HE'S NOT YELLING - IT'S THE ACCENT
Old 10-05-2004, 12:36 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
There is no provision for mounting the clutch master cylinder on the firewall zero, zip, nada,so you must get a chunk of firewall from a 5spd chassis cut yours and rivet , glue it in place(welding is a fire issue). The list of needed parts is EXTENSIVE and EXPENSIVE ....... thousands of dollars even used . The best way is to buy a complete wrecked S-4 , 5 speed car and park it beside the automatic and take off everything you need. Like bellhousing ,flywheel, central tube,all clutch items, clutch master, clutch slave , hoses,shift linkage, clutch pedal .....for it to have PSD it must be 1990 or newer . Your instrument cluster will still say PND32 unless you change the gauge. You have to overide the neutral safety switch and mickey mouse the reverse switch since the rear car harness is a bit different. And I am probably forgetting a few other things ......
Old 10-05-2004, 12:42 PM
hacker-pschorr
I was actually thinking the same thing!
Jim - C'mon man, don't discourage him. Just because this is the equivalent to performing a sex change on a human, doesn't mean he's not up to the challenge!
Go for it!
Old 10-05-2004, 12:46 PM
Shane
Sharkaholic
Shane's Avatar
I converted my auto to a 5sp by buying a five speed and having both. As everyone has mentioned "lots of dollars and lots of grief". By having two 928s you can work on one and drive the other, or there will be days when you prefer not to shift and drive the auto, or vice versa. Good Luck in your choice.
Old 10-05-2004, 01:09 PM
Hacker ,note that I never said it could not be done. I think we have "helped" 4 or 5 people who have done this conversion. The question is SHOULD it be done. That can only be answered by how badly does one wish to do it ? because from a financial point of view it makes little sense at all. If you tell me you are considering jumping blindfolded off a cliff ; I am probably going to point out how high the cliff is. Then it is your decision to jump or NOT. In this case I suggest he buy a parachute (a complete 5 spd parts car) before he jumps!
Old 10-05-2004, 06:05 PM
Vilhuer
Vilhuer's Avatar
Wasn't there complete procedure with pictures in this website earlier?
http://www.kondratyev.com/porsche/te...ansmission.htm
Old 10-05-2004, 06:53 PM
heinrich
928 Collector
heinrich's Avatar
Old 10-06-2004, 08:05 AM
slate blue
slate blue's Avatar
Here is a good link provide by my mate Stu, I used this info to covert my car, also you need a GT or GTS box, nothing else will do.
How to
Quick Reply: S4 AUTO TO MANUAL CONVERSION
