924 and 931 Forum 1976-1988
fuel pump relay
Old 01-18-2002, 05:09 PM
Dan924
Dan924's Avatar
Red face fuel pump relay
Hi all, ok i got this very interesting fuel pump relay...it never starts the fuel pump untill i bypass the relay on a the #87 (power wire???)...
i wonder if it's my relay is shot to death or is it something in the wiring, but i just can't get it to work unless i bypass it, i just connect a power to the 87's wire and then the fuel pump works but to shut it off i have to disconnect the battery.
the year of 924N/A is '77 and the relay # is 477 906 059... i have checked and it's a right number for my car...i guess i need now a new relay and it's so expensive here. Does anyone has a fuel pump relay kicking around?
Old 01-18-2002, 05:29 PM
BigPorscheGuy39
BigPorscheGuy39's Avatar
Post
I think that's the same fuel pump relay as in the 931. I'll check and get back to you. I might have more than one kicking around.
Old 01-18-2002, 05:33 PM
Dan924
Dan924's Avatar
Post
Thanx BigPorscheGuy
Old 01-19-2002, 06:45 PM
Diesel924
Diesel924's Avatar
Post
It's not. Two different part numbers.
Quick Reply: fuel pump relay
