Cheap Axle Alternative
#166
This thread is still alive and well, I see.
Just to report back, I am still daily driving on mine without problem. I haven't touched them from the first time I installed them and they seem to be doing great.
As a mention, worn suspension and wheel hop can kill axles as well. Luckily my setup doesn't wheel hop and that's with 550lb springs in the rear and no t-bars.
#167
Busted the inner cage on the drivers side late yesterday afternoon at Barber. This was a 944 part that had been on the car for years with occasional greasing. I plan on installing the vanagon part that I bought long ago but am trying to decide if I'm going to install it whole, or just use the CV's on my porsche shaft.
#168
WRONGLY ACCUSED!
Received 3,278 Likes
I have three track days on my set now and no problems even after some very spirited driving.
Just received another one which I am keeping as a spare when I go to the track.
#170
Anyone been running these for 968 boxes w/ unequal length shafts?
#171
Someone in another post mentioned that EMPI makes a chrome moly cv joint. Does anyone know if these will fit the 25 spline axles used on the TS? I guess I can call EMPI and find out. Thanks, Mike
#173
I can't correct you on this but i do have a question:
Is there anyone who ships these axles to Europe? At this moment they do not provide shipping to the Netherlands and the axles here are still 250euros a piece..
#174
Ok so i broke my left inner CV joint today.
1 new CV joint in sweden costs around $175
I don´t know the condition of the other CV joints on the car.
So i´m thinking it´s cheaper to buy the hole kit from the states like this one
http://www.ebay.com/itm/EMPI-90-6805...2&vxp=mtr#shId
or is this better?
http://www.ebay.com/itm/GSP-AMERICA-...c91c1d&vxp=mtr
is it the same to both left and right side
Edit
i found this but it´s for 33 splines
http://www.ebay.com/itm/EMPI-98-5084...d082c9&vxp=mtr
To bad
or is this better?
Edit
To bad
#175
It´s very quiet in here
I found the axles in germany for around the same price and i avoid customs fee
Only problem is that i don´t know if it´s EMPI who makes them
http://www.ebay.de/itm/2x-Antriebswe...item4843e9fc50
#176
#178
The way I did it was to drain the tranny and remove the cooling loop. Takes about 15 minute to get it out and if you drain the fluid into a clean bucket and if the fluid isn't that old you can reuse it. I'm sure there's some combination of tools and German voodoo that would allow you to get the axle out without removing the cooling loop but I didn't want to chance damaging the loop. Price a replacement cooling loop and you will see why.
#180
Loosen all bolts, trans side first followed by trailing arm, (I stick a flat head screwdriver into a rotor slot in center of caliper to hold assembly), pull all bolts back to boot but do not remove, dislodge/push inner cv up and slightly towards front of car and inTo space above and in front of fuel filter, now dislodge outer cv from trailing arm and push axle up, then pull whole axle down and out. Install is reverse. Because EMPI axles are a bit longer, you may need to loosen/unbolt trans support to move trans sideways get enough room to dislodge/install inside cv. Mike
