Brake line routing 944
Old 04-04-2006, 04:24 PM
Iwan
Iwan's Avatar
Question Brake line routing 944
My garage is going to make me up and fit some coper brakelines (nice man) for the back of my 88 UK spec 944 (2.5 l).
The problem is there's no diagram available in the Porsche Workshop Manual or Haynes for the routing of the pipes. There's a 4 way splitter (at the rear) of the car and one pipe seems to go forward - behind all sorts of exahust shields.
This is a UK car (with the steering wheeel on the correct side of course ) does anyone have:
A) A diagram?
B) Experience of replacing the hard pipes
c) A source for said diagram?
I'd be pleased if someone can offer any advice
Iwan
Iwan is offline
Old 04-29-2006, 08:50 PM
cjeckert
cjeckert's Avatar
um wrong forum try the water cooled 924/944/951/968 tech area.
cjeckert is offline
Old 07-15-2006, 11:22 AM
bigal13
bigal13's Avatar
hi
just replaced all my brake pipe lines on a 1986 944 should be the same routing as you would have, at the rear there's a 3 way splitter (NOT 4) on my car anyway one pipe is the feed from the brake servo and the other 2 one goes to each of the rear wheels, as for routing just replace as they come off and rout the same way, at the same time i replaced the flexible lines as well mine is the originals so you could guess how the looked
bigal13 is offline
Quick Reply: Brake line routing 944
