Video: Replacing the engine mounts
Old 02-21-2017, 06:37 AM
Dr944S2
Dr944S2's Avatar
Default Video: Replacing the engine mounts
Hi,
the video gives you a step by step tutorial how to replace the engine mounts on the Porsche 944. The hydraulic engine mounts lose their damping capacity with time, a mount is worn to the limit, when the installed height is less than 62 mm or the height of the removed and de-tensioned mount is less than 65 mm.
The video has a German soundtrack but English subtitles are available at YouTube. If you don't see them by default, watch the video directly at YouTube and press the subtitle button below the frame.
Enjoy it,
Jürgen
Old 02-21-2017, 09:13 AM
thomasmryan
thomasmryan's Avatar
I like the crows foot inverted method with the extension on the combination wrench
Old 02-21-2017, 03:45 PM
culture
culture's Avatar
^^^care to eleaborate?
Old 02-21-2017, 07:12 PM
thomasmryan
Jürgen set a short 13mm closed end of a combo wrench on the upper mount bolt then used an extension for access.
Old 02-22-2017, 04:51 AM
Dr944S2
Dr944S2's Avatar
Hi,
I used a 12 - 13 mm double box-end wrench. The 13 mm fit at the bolt and the 12 mm I operated with a 12 mm Allen socket.
Greetings,
Jürgen
Quick Reply: Video: Replacing the engine mounts
