Air Bag System Nuts
Air Bag System Nuts
The nuts left behind by the break-off bolts used to attach air bag system components in our cars are unique and I have been able to overcome the uniqueness by using a pair of small vice grips up until the last dam nut. The location prevents use of the vice grips.
Anyone have the nut removal tool by chance?
Photo attached...
Photo attached...
David pagan Promotion air bag system nuts
Cheap Tool Tip:
you can get a cheap socket and cut around the out side reverse triangular indentations thus it would look like a hole saw . attached to your extension and when removing push against the nut ( teeth grab teeth and it's removed ) .
Actual tool pictured
Yeah, that tool is outrageous!
http://www.samstagsales.com/Porsche.htm#quicksearch
Quoted 4 week lead time and $150.
