Central lock + button installation
Perhaps a silly question, but here goes. Planning to install an aftermarket generic central locking system incl actuators and remote. My car does not have nothing of the central locking stuff from original. I think the installation is pretty straightforward, but I usually like to complicate things. In this case an original central locking switch which I've acquired. Would it be hard to hook it up to the new power locking? I'm no electrical wizard, but I can do basic work.
Many tips and hints are appreciated!
For starters, you'll need the wiring diagram of the kit that you're using, and the socket that that switch plugs into.
But sure, I don't see why you couldn't make it work. Just a matter of figuring out which pins make contact when pressed, and which wires of your new control unit to connect them to.
