Inexpensive holder for aftermarket plug wires - pics
Hi friends - Not sure if this has been posted before.
For 8mm and above diameter plug wires, the stock factory plastic holders will over time pinch and damage the insulator \ jacket of your expensive wires.
Here is the $6.00 solution that takes zero time, no cutting or drilling.
Order this from Summit Racing:
https://www.summitracing.com/parts/trd-9577
Go to your favorite hardware store and get some longer M4 bolts to replace the ones that come in the above kit
Remove the factory holders and the holes left in the bracket install the new holders and away you go, without damaging your new wires.
