sway bar swap
Old 01-13-2017, 11:59 AM
mbufkin
8th Gear
mbufkin's Avatar
Default sway bar swap
I will swap my Weltmeister sway bars (29 mm front and 22.5 mm rear) for a set of original 944 S2 bars. Anyone interested?
Old 01-13-2017, 12:10 PM
porscharu
porscharu's Avatar
Where are you located?
Old 01-13-2017, 12:47 PM
mbufkin
8th Gear
mbufkin's Avatar
Default Location
I am in Atlanta.
Old 01-13-2017, 01:28 PM
Legoland951
Legoland951's Avatar
I have a set of turbo sway bars (same as S2) to swap. PM me. I believe the front bar is 27mm.
Old 01-13-2017, 02:34 PM
snb13
snb13's Avatar
I also have a set. 26.8mm front, 19mm rear.
Old 01-17-2017, 09:03 PM
mwc951
mwc951's Avatar
Why do you want to do this?
I though the Weltmeister bars are an upgrade from stock.
Old 01-17-2017, 10:40 PM
mbufkin
8th Gear
mbufkin's Avatar
The Welts are a little stiff and noisy. I want to return the car to original.
Old 01-18-2017, 12:06 PM
AgLiftPilot
AgLiftPilot's Avatar
We have a stockpile of OEM 944 parts at the 944Spec parts depository called the Chicken Shack up in Cumming, GA, not far outside Atlanta. I can check to see if we have any OEM bars laying around gathering dust in those sizes. We ditch all the stock stuff in favor of the M030, Welt, or Tarrett bars for racing.
Are you looking for 26mm front and 16mm rear? We also have several two post lifts that we can use to do the swap on site to make it easy if you want.
Old 01-18-2017, 01:38 PM
mbufkin
8th Gear
mbufkin's Avatar
I believe the 26/16 is the orignal 944 S2 setup, and that is what I want. I have the Weltmeisters boxed up with all hardware and would like to drive up and complete the swap. When would be a good day? Tomorrow or next Tuesday - Friday are best for me.
Give me a call at 404 2343487
Old 01-18-2017, 02:58 PM
AgLiftPilot
Checking tonight to see what sizes we have laying around and then will let you know.
Quick Reply: sway bar swap
