Head Restoration for corroded 944/951/968 heads
Old 01-10-2017, 11:16 AM
Carl Fausett
Developer
Carl Fausett's Avatar
Default Head Restoration for corroded 944/951/968 heads
We now are offering a head restoration service for 944, 951, and 968 heads.
If you have badly corroded heads like these below - we probably can save them! Some of these heads are getting very hard to come by (like 951 heads) and restoring them is way cheaper and faster than finding replacements.
Here is the link:
https://928motorsports.com/services/...estoration.php
Pricing:
16v heads: $310 each head
32v heads: $360 each head
* Pics below are 16v 928 heads. I am doing a set of 928 GTS heads now, will post before-and-after pics for them as soon as I can.
Old 01-10-2017, 11:46 AM
V2Rocket
Rainman
V2Rocket's Avatar
Beautiful work.
Old 01-10-2017, 12:52 PM
kevin12973
kevin12973's Avatar
What causes this severe corrosion to happen? Incorrect antifreeze?
Old 01-10-2017, 01:25 PM
car3guy
car3guy's Avatar
Now that is a thing of beauty, amazing, wow
Old 01-10-2017, 02:24 PM
MAGK944
MAGK944's Avatar
Good to know and thanks for offering this service.
Old 01-10-2017, 06:08 PM
tempest411
tempest411's Avatar
That's amazing you can save those, and for the cost involved, an excellent value as well.
Old 01-10-2017, 06:41 PM
jhowell371
jhowell371's Avatar
Wow, nice work.
Old 01-11-2017, 12:13 PM
Carl Fausett
Developer
1) Maintain a quality anti-freeze in your system that has the right additives. In this case, corrosion inhibitors for aluminum.
2) do not use tap water - especially if you know yours has a lot of mineral content (promotes ionization). Use distilled water.
3) maintain a good ground between the engine and the chassis. Merely looking to see that your ground strap is in place is not enough. Many have removed their engine ground strap and discovered it is badly corroded inside. Replace as needed.
Here is a pretty good article about cooling system corrosion via electrolysis:
http://www.aa1car.com/library/coolin..._corrosion.htm
Old 01-11-2017, 12:27 PM
thomasmryan
thomasmryan's Avatar
This. pH matters.
Quick Reply: Head Restoration for corroded 944/951/968 heads
