Lowering Suspension Questions
#61
Whoops! Sorry.
Justin, thanks for getting those 250 lb/springs for me.
Question about DELRIN.
Since I'm seriously considering delrin sway bar and front & rear control arm bushings... for the street mostly with some track use. Is delrin to noisey/squeaky? or should I go rubber?
#62
Never tried them, a friend did..they made noises and wore out.
Years ago I measured and made a drawing for a delrin shifter bushing..the one next to the gearbox.
Its worn faster than the 30+ years old part even though I designed minimal play between the metal and the bushing.
If you want stiffness go for polyurethane.
You can buy the powerflex bushings from ideola's garage or there are other options.
#63
Motion ratio on front springs...M(f) = ~0.9
Motion ratio on rear springs...M(r) = ~0.65^2 [~0.42]
M(r) does not apply to torsion bars.
Ergo...Morghen's 924 GTS is running equivalent spring rates of ~252 lb/in [280 * 0.9] up front and ~211 lb/in [~137 + (200 * 0.42)] out back. This is in line with the real world result he reports...relatively neutral handling, with probably a slight tendency to understeer when pushed.
#64
Not completely correct.
What 's the Wheel rate ? is this different or the same thing
If the front (.9 rate) is on the shorter 924 wishbone, what's the longer later 944 / 968 type?
Does an incorrect wishbone angle from excessive lowering change the motion ratio or not? and this only affects the camber change?
The rear Hollow 27mm T bars I have currently fitted Elephant Racing rate at 220Lbs, so this computes to 132 Lbs actual ? and my 190Lbs fronts 171Lbs
which would also explain why have a hit if understeer also if the rear is 30% softer Correct?
R
#65
My mistake.
Where I said motion ratio, I should have said wheel rate. Have always seen rear wheel rate from a coilover spring calculated as: W(r) = M(r)^2 * spring rate, where M(r) = ~0.65
And have always seen front wheel rate calculated as: W(f) = M(f) * spring rate, where M(f) = ~0.9
But, as previously mentioned, motion ratio does not apply to torsion bars. Your 220 lb/in-rated 27 mm bars convey to the torsion/coilover summation equation directly [220 lb/in], as they are axially coincident with the spring plate pivot point.
Re: early offset/late offset control arms...good question. Have not seen anyone reference different numbers for front motion ratio to compensate for the ~25mm difference.
Re: your slight understeer...suspect that can be attributed more to your oversized 26.8 mm sway [with respect to your lightweight chassis] than to the difference in front-to-rear spring rate. Suggest you either step down the front bar or step up the rear bar.
#66
My mistake.
For Sprints & a Production competition I was thinking of sorting the Non parrallel Wishbones, and tie rods then Increasing the front springs to 250Lbs and fitting coil over Springs as well as the T bars, so looking a the above calulations the rear springs would need to be about 150Lbs? if the 220lb T bars simply add the coil spring rate on top (total 370Lbs) but the .65 rear coil wheel rate is 97.5 (Wheel rate Total 317.50Lbs)
R
#67
#68
Take care with poly as well..
As far as I understand the material, Delrin is not high resilience and will take a set...make noises and affect alignment.
#69
Rear W(r) = ~220 lb/in...correct [for 27 mm torsions]
Rear W(r) = M(r)^2 * spring rate
Rear W(r) = 0.65^2 * 150 = ~63.4 lb/in
Total rear W(r) = springs + torsions = ~63.4 + ~220 = ~283.4 lb/in
#70
.65 of 150 is 97.5 ?
R
#73
He probably means B8's. not a kit, just another bilstein shock.
#75
